Full Version: [WIP] HTPC-Manager Beta, Manage XBMC, Sabnzbd, SickBeard with one app
I can't find a method to create a playlist on Kodi.
Do you mean helix? I see several examples in xbmc.py
I'm talking about the xbmc (kodi) api.
(2014-09-06, 00:27)MadClicker Wrote: [ -> ]I'm talking about the xbmc (kodi) api.
There is a playlist.add and so on. 5.10 in jsonrcp api. Isn't that what you talking about?
I think that just adds items to an existing playlist.
Curious if there are plans to add nzbdrone to the manager?
(2014-09-06, 14:43)Frozin Wrote: [ -> ]Curious if there are plans to add nzbdrone to the manager?
I plan to send a pr. Its like half finished atm, its missing stuff like add/edit shows and basic commands. However that does not mean that it will be added, thats up to styxit
I'm constantly getting this error modules.sickbeard ERROR Unable to fetch information
I'm using sickrage, which may be why i get the error. Sometimes the info populates other times it doesn't.
(2014-09-07, 11:36)Frozin Wrote: [ -> ]I'm constantly getting this error modules.sickbeard ERROR Unable to fetch information
Sickrage api tends to break every other update. The call is correct (so far) but sickrage returns error 500. I plan to do add some sickrage features but cba with the api atm
is there nzbdrone support for HTPC Manager.
(2014-09-21, 20:11)Svenvg93 Wrote: [ -> ]is there nzbdrone support for HTPC Manager.
Not yet, but have started on a repo.
(2014-09-21, 21:22)hellow Wrote: [ -> ]
Nice!!!
Awsome! Btw I think the Nzbdrone devs are more than willing to work with others to improve/expand their API. I remember them offering to help in other forums (I think it was for that other semi-popular frontend).
https://github.com/styxit/HTPC-Manager/issues/251
https://github.com/styxit/HTPC-Manager/issues/235
Couchpotato library is rendering empty. Everything else is perfect. This is running in a Freenas plugin. Let me guess, no love on the horizon as getting the update that was pushed in the git thread to the plugin?Huh
(2014-09-25, 04:40)darthanubis Wrote: [ -> ]https://github.com/styxit/HTPC-Manager/issues/251
I think you will have better luck on the freenas forum. I assume someone there made it Tongue
