(2014-11-17, 22:03)hellow Wrote: [ -> ]I added a delay before the page reloads now. Can you check, if this work I'll send this upstream aswell
I have noticed that "other apps" tab saves it's settings fine. no other tabs to.
This is the debug from the addition of the delay.
http://pastebin.com/wvTRq01M
Shows at the start trying to save the settings to database a few times
What browser are you using?
Safari, can try in chrome if that maybe an issue?
Dunno, don't have a mac to test on. Works fine on my iPhone tho
My god, safari sucks. Sorry. Chrome works fine, settings where being saved too just not displayed via safari.
(2014-11-17, 22:45)hellow Wrote: [ -> ]Glad it worked out
Thank you very much for your help
Just had to re-install the app on another pc. Wanted to make the following suggestion.
1- Setting import/export capabilities. found it a pain to have to redo all the setting for the same environment -- still not finished.
2- Stats Options. - The ability to select what is displayed. Instead of manual listing what is ignored.
Love the app!
(2014-11-20, 03:12)ylafont Wrote: [ -> ]Just had to re-install the app on another pc. Wanted to make the following suggestion.
Great idea, in the mean time you can copy the db over to the new computer
I'll add a option where you can choose if mountpoint and fstype should be a treated as a whitelist or blacklist.
Love the app!
I have merged your request regarding stats module in my own branch and sent a pr upstream. Dont hold your breath tho.
(2014-11-20, 23:30)hellow Wrote: [ -> ]I have merged your request regarding stats module in my own branch and sent a pr upstream. Dont hold your breath tho.
Thanks for the quick response hellow, glad the to know suggestion are being considered. looking forward to testing it.
Ive been reading and I dont see if anyone came up with a way to run this without having the command window open? Can someone point me in the correct direction?
(2014-11-24, 23:56)Predator004 Wrote: [ -> ]Ive been reading and I dont see if anyone came up with a way to run this without having the command window open? Can someone point me in the correct direction?
For windows:
Right click Htpc.py. Select open with, choose default program, browse for pythonw.exe. Press enter.(Check for always open with the selected program. Make a shortcut and drag to Startup folder)
(2014-11-25, 02:54)hellow Wrote: [ -> ] (2014-11-24, 23:56)Predator004 Wrote: [ -> ]Ive been reading and I dont see if anyone came up with a way to run this without having the command window open? Can someone point me in the correct direction?
For windows:
yes thats how i have it.. but i have to keep the command window open. if i close it it shuts down the server. So i want to be able to run the server in the background like sickbeard or sab. any ideas?
Make sure it's pythonw.exe not python.exe
