(2016-03-30, 16:04)osharko Wrote: [ -> ]hi, i'm quite confuse about the installation of HTPC manager on my homemade NAS, i come from synology os and i'ld like to find a configuration like it.
i have to :
- Reproduce video like it's netflix (i have the 70% of the video encoded with h265, is there any app to encode them?)
- Access to all the file (obviously)
- Use DDNS (but maybe this depends on os..)
Then.. i tryed to configure from the web client, but i don't know hot to do
Htpc manager don't do anything of what you want. It's a interface to manage different services and limit access.
You can use ffmpeg to encode the videos and mb3 or plex to stream you own content to your browser/tv/app
thank you
(2016-04-07, 15:45)darksheep Wrote: [ -> ]Hi
Will this ever support https://sonarr.tv/ ?
You can try my fork if you want support for sonarr. Or wait for somebody to add it to htpc manager. The main project seems dead.
I'm having trouble with a reverse proxy set up. If I just access htpc manager by going to my externalip:port all my modules work fine but if I go to my.dns.net/htpcmanager I can log in to it but all of the modules don't work. If I do a test on settings they all pass which is why this is so weird.
Post your reverse proxy config.
im having the same issue. the modules for thew dashboard dont work except for plex
heres my reverse proxy setup
removed server name and ip
#user nobody;
worker_processes 1;
#error_log logs/error.log;
#error_log logs/error.log notice;
#error_log logs/error.log info;
#pid logs/nginx.pid;
events {
worker_connections 1024;
http {
include mime.types;
default_type application/octet-stream;
#log_format main '$remote_addr - $remote_user [$time_local] "$request" '
# '$status $body_bytes_sent "$http_referer" '
# '"$http_user_agent" "$http_x_forwarded_for"';
#access_log logs/access.log main;
sendfile on;
#tcp_nopush on;
#keepalive_timeout 0;
keepalive_timeout 65;
#gzip on;
server {
listen 80;
server_name ----------------------------;
#charset koi8-r;
#access_log logs/host.access.log main;
location / {
proxy_pass http://127.0.0.1:8085;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
location /plexrequest {
proxy_pass http://127.0.0.1:3579;
location /couchpotato {
proxy_pass http://127.0.0.1:5050;
location /sonarr {
proxy_pass http://127.0.0.1:8989;
location /gui {
proxy_pass http://localhost:8285/gui;
location /utorrent {
location /jackett {
proxy_pass http://127.0.0.1:9117/jackett/;
#error_page 404 /404.html;
# redirect server error pages to the static page /50x.html
error_page 500 502 503 504 /50x.html;
location = /50x.html {
root html;
# proxy the PHP scripts to Apache listening on 127.0.0.1:80
#location ~ \.php$ {
# proxy_pass http://127.0.0.1;
# pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
# root html;
# fastcgi_pass 127.0.0.1:9000;
# fastcgi_index index.php;
# fastcgi_param SCRIPT_FILENAME /scripts$fastcgi_script_name;
# include fastcgi_params;
# deny access to .htaccess files, if Apache's document root
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
# another virtual host using mix of IP-, name-, and port-based configuration
#server {
# listen 8000;
# listen somename:8080;
# server_name somename alias another.alias;
# location / {
# root html;
# index index.html index.htm;
# HTTPS server
#server {
# listen 443 ssl;
# server_name localhost;
# ssl_certificate cert.pem;
# ssl_certificate_key cert.key;
# ssl_session_cache shared:SSL:1m;
# ssl_session_timeout 5m;
# ssl_ciphers HIGH:!aNULL:!MD5;
# ssl_prefer_server_ciphers on;
# location / {
# root html;
Any plans on adding Deluge dashboard support ?
Last commit is over a year ago. So probably not
Sent from my LG-VS985
Hi All,
Is anyone able to assist with the connection between HTPC and Plex?
Have configured Plex in HTPC, the "Test" works but when I attempt to see Plex content in HTPC-Manager It says it cannot connect.
I get this error message in the HTPC-Manager logs:
modules.plex ERROR Unable to fetch currently playing information! Exception: '_children'
As @
hellow mentioned in a very subtle(humble?) way, this project appears dead and his port has a lot more improvements above the state of this repo. You can find it at
https://github.com/Hellowlol/HTPC-Manager .
I hope the moderator would update the OP to link to this repo.
Hi all!
Im a Synology NAS user and i found this app in the SynoCommunity app list of my NAS.
The HDMI ports on my TV are broken so i cannot connect a pc or android device which has KODI, however i can connect by DLNA to my NAS to watch tv shows/movies/music/etc on this HDMI-less TV.
Quick question...
Can i use this program to feed out files from my NAS to watch them on this TV ?
As it is.. the files work through the TV's DLNA setup and im not sure of anywhere there is any kind of Chromecast-like setup i can use instead (Chromecast not built into this TV)
Thanks in advance.
Silencerbob
Silencerbob, that's not what this program does at all.
I am running HTPC manager on a Ubuntu server. However i am having some issues with the "system" module. It's not showing any system information but instead shows:
smartmontools
Python should be executed as an administrator to smartmontools to work properly. Please, try to run python with elevated credentials.
Can someone explain to me what i am supposed to do to get this working? My linux terminal knowledge is not very big and this is a headless machine.
Python is installed and it's the latest version. However i have no idea how to "elevate the credentials" for Python.
Kasper
(2017-03-19, 17:23)kasper1985 Wrote: [ -> ]Hi,
smartmontools
Kasper
Hi. You need to use sudo python htpc.py
