Full Version: No auto-login Eden - Solved
Okay,
I just did a ...
sudo apt-get update
sudo apt-get install xbmc
on my XBMC Live (Dharma). Everything regarding the installation went fine. But now when the computer reboots it ask me for username and password. If I connect a keyboard and type in username and password and then write startx XBMC Eden will start. But how do I get rid of the username/password prompt? I want auto-login.
********* Solution *********
I just solved the problem by following this post...
http://forum.xbmc.org/showthread.php?tid=117645&page=3
Thank you for this!
