I installed Eden today, first time I try XBMCbuntu. I've always used XBMC on Windows.
Anyhow, the wired network doesn't work.
I've got a Zotac box with the infamous r8169 network module, so naturally first thing I tried was to change it to r8168. I managed to do so, but still no wired network. Wireless workes fine though, I'm on wifi as I'm typing this.
lspci -v
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 03)
Subsystem: ZOTAC International (MCO) Ltd. Device 8168
Physical Slot: 32
Flags: bus master, fast devsel, latency 0, IRQ 43
I/O ports at d800 [size=256]
Memory at fbffb000 (64-bit, prefetchable) [size=4K]
Memory at fbffc000 (64-bit, prefetchable) [size=16K]
Expansion ROM at feae0000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: r8168
Kernel modules: r8168
ifconfig
eth0 Link encap:Ethernet HWaddr XX:XX:XX:XX:XX:XX
inet6 addr: XXXX::XXX:XXXX:XXXX:XXXX/XX Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:198 errors:0 dropped:0 overruns:0 frame:0
TX packets:43 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:32702 (32.7 KB) TX bytes:12378 (12.3 KB)
Interrupt:43
dmesg | grep eth0
[ 1.661522] eth0: Identified chip type is 'RTL8168D/8111D'.
[ 14.081608] r8168: eth0: link down
[ 14.082127] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.175045] r8168: eth0: link up
[ 17.175454] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 18.080025] r8168: eth0: link up
[ 27.800014] eth0: no IPv6 routers present
Any ideas?
Can you post your lspci -v with root access?
I'm running debian here:
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
Subsystem: ASUSTeK Computer Inc. P8P67 and other motherboards
Flags: bus master, fast devsel, latency 0, IRQ 45
I/O ports at d000 [size=256]
Memory at d0004000 (64-bit, prefetchable) [size=4K]
Memory at d0000000 (64-bit, prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
Capabilities: [d0] Vital Product Data
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number a3-00-00-00-68-4c-e0-00
Kernel driver in use: r8169
Though this is on a Asus/Zacate board.
Can you post modinfo r8168?
modinfo r8169
filename: /lib/modules/3.2.0-1-amd64/kernel/drivers/net/ethernet/realtek/r8169.ko
firmware: rtl_nic/rtl8168f-2.fw
firmware: rtl_nic/rtl8168f-1.fw
firmware: rtl_nic/rtl8105e-1.fw
firmware: rtl_nic/rtl8168e-3.fw
firmware: rtl_nic/rtl8168e-2.fw
firmware: rtl_nic/rtl8168e-1.fw
firmware: rtl_nic/rtl8168d-2.fw
firmware: rtl_nic/rtl8168d-1.fw
version: 2.3LK-NAPI
license: GPL
description: RealTek RTL-8169 Gigabit Ethernet driver
author: Realtek and the Linux r8169 crew <[email protected]>
srcversion: B4DBE6621AC5024B6F727C8
alias: pci:v00000001d00008168sv*sd00002410bc*sc*i*
alias: pci:v00001737d00001032sv*sd00000024bc*sc*i*
alias: pci:v000016ECd00000116sv*sd*bc*sc*i*
alias: pci:v00001259d0000C107sv*sd*bc*sc*i*
alias: pci:v00001186d00004302sv*sd*bc*sc*i*
alias: pci:v00001186d00004300sv*sd*bc*sc*i*
alias: pci:v000010ECd00008169sv*sd*bc*sc*i*
alias: pci:v000010ECd00008168sv*sd*bc*sc*i*
alias: pci:v000010ECd00008167sv*sd*bc*sc*i*
alias: pci:v000010ECd00008136sv*sd*bc*sc*i*
alias: pci:v000010ECd00008129sv*sd*bc*sc*i*
depends: mii
intree: Y
vermagic: 3.2.0-1-amd64 SMP mod_unload modversions
parm: use_dac:Enable PCI DAC. Unsafe on 32 bit PCI slot. (int)
parm: debug:Debug verbosity level (0=none, ..., 16=all) (int)
In either cases, on debian the r8169 module hosts firmware/drivers for r8168 as well.
Thanks, here's what I get (fresh install, so I'm back on the r8169 module)
Physical Slot: 32
Capabilities: [ac] MSI-X: Enable- Count=4 Masked-
Capabilities: [cc] Vital Product Data
Capabilities: [160] Device Serial Number 3c-4e-00-00-68-4c-e0-00
Kernel modules: r8169
filename: /lib/modules/3.0.0-16-generic/kernel/drivers/net/r8169.ko
version: 2.3LK-NAPI
license: GPL
srcversion: 91BDC1109C31F7EEF7E9783
depends:
vermagic: 3.0.0-16-generic SMP mod_unload modversions 686
lspci -v from my other computer.
Same chip, different rev. Works like a charm
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
Subsystem: Giga-byte Technology GA-EP45-DS5 Motherboard
Flags: bus master, fast devsel, latency 0, IRQ 41
I/O ports at de00 [size=256]
Memory at fbeff000 (64-bit, prefetchable) [size=4K]
Memory at fbef8000 (64-bit, prefetchable) [size=16K]
Capabilities: [160] Device Serial Number 01-00-00-00-68-4c-e0-00
I don't understand your complaint. From the data in your original post, it looks like eth0 is up and running. The messages log looks normal.
You need to verify your network settings in network-manager gui from the ubuntu desktop.
If you are not useing IPv6, you should disable it. This will speed up your IPv4 connectivity. It can be disabled by selecting "Ignore" from the pull-down on the IPv6 tab in network manager.
ethtool confirms, link is up...but it doesn't get an IP from the router?
I have set ipv6 to ignore, but that didn't help
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00000033 (51)
drv probe ifdown ifup
Link detected: yes
