I installed XBMC Eden final on my Mac Mini today and after exiting AirPlay video from iPad, XBMC is often freezing completely and I have to restart. Very frustrating and making AirPlay unusable for me.
Anybody else experiencing this and is there a solution?
Thanks in advance.
no and no because of the first no. which airplay app and which ios version on the client are you using?
Youtube video on iOS 5.1 / iPad 2. No jailbreaks.
Airplay mirroring doesnt work either - nothing is displayed.
Airplay mirroring is not supported (shouldn't be selectable as a target - i'm really confused about that!). Don't have iOS 5.1 and won't get it until a untethered JB is out. Could you post a xbmc.log with debugging enabled to pastebin.com and put the link here?
I suspected mirroring wasn't supported since nothing happened, but thought I should mention it
It is selectable though.
I will try to make a log file tonight and post it.
/B
I've got exactly the same problem as the first post in this thread.
Running Eden on Win7 and iOS 5.01 as the client.
post a logfile - can't reproduce - works fine here
Same problem for me. I have been using XBMC for a few days now on my Media Center XP, but every time I play an airplay video the whole XBMC app hangs and has to be ended.
If I can work out how to find that debugging option, i'll post it to whoever asks for it.
Yeah nice one. Debugging file is already present and a scan shows an airplay video (which played to completion successfully).
Quote:13:35:44 T:3880 NOTICE: DVDPlayer: Opening: http://<IPHONEIP>:7001/1/8a177052-2e09-5843-ae23-ec834864c7e4.MOV|User-Agent=AppleCoreMedia%2f1%2e0%2e0%2e8F455%20%28AppleTV%3b%20U%3b%20CPU%20OS%204%5f3%20like%20Mac%20OS%20X%3b%20de%5fde%29
13:35:44 T:3880 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
13:35:44 T:556 NOTICE: Creating InputStream
13:35:44 T:556 NOTICE: Creating Demuxer
13:35:45 T:556 NOTICE: Opening video stream: 0 source: 256
13:35:45 T:556 NOTICE: Creating video codec with codec id: 28
13:35:45 T:556 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
13:35:45 T:556 NOTICE: Creating video thread
13:35:45 T:556 NOTICE: Opening audio stream: 1 source: 256
13:35:45 T:556 NOTICE: Finding audio codec for: 86018
13:35:45 T:3660 NOTICE: running thread: video_thread
13:35:45 T:556 NOTICE: Creating audio thread
13:35:45 T:2988 NOTICE: running thread: CDVDPlayerAudio:rocess()
13:35:45 T:2988 NOTICE: Creating audio device with codec id: 86018, channels: 1, sample rate: 44100, no pass-through
13:35:45 T:3660 NOTICE: fps: 30.000000, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
13:35:45 T:3660 NOTICE: Display resolution DESKTOP : 1920x1080 @ 60.00 - Full Screen (12)
13:35:53 T:3660 NOTICE: fps: 29.970030, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
13:35:53 T:3660 NOTICE: Display resolution DESKTOP : 1920x1080 @ 60.00 - Full Screen (12)
13:35:55 T:3660 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
13:36:09 T:2988 WARNING: Previous line repeats 4 times.
13:36:09 T:2988 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
13:36:45 T:556 WARNING: Previous line repeats 27 times.
13:36:45 T:556 NOTICE: CDVDPlayer::OnExit()
13:36:45 T:556 NOTICE: DVDPlayer: eof, waiting for queues to empty
13:36:45 T:556 NOTICE: DVDPlayer: closing audio stream
13:36:45 T:556 NOTICE: Closing audio stream
13:36:45 T:556 NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
13:36:46 T:556 NOTICE: Waiting for audio thread to exit
13:36:46 T:2988 NOTICE: thread end: CDVDPlayerAudio::OnExit()
13:36:46 T:556 NOTICE: Closing audio device
13:36:46 T:556 NOTICE: Deleting audio codec
13:36:46 T:556 NOTICE: DVDPlayer: closing video stream
13:36:46 T:556 NOTICE: Closing video stream
13:36:46 T:556 NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
13:36:46 T:556 NOTICE: waiting for video thread to exit
13:36:46 T:3660 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
13:36:46 T:3660 NOTICE: thread end: video_thread
13:36:46 T:556 NOTICE: deleting video codec
13:36:46 T:556 NOTICE: CDVDPlayer::OnExit() deleting demuxer
13:36:46 T:556 NOTICE: CDVDPlayer::OnExit() deleting input stream
13:36:46 T:3880 WARNING: Skin has invalid include: BigIconView
13:36:46 T:3880 WARNING: Previous line repeats 3 times.
I can't see my attachment options where I would normally in PHPBB or other forum software... so i'm guessing i'm on a limited thingy.
Close. Now we just need you to enable debugging and post it to a paste site like pastebin.org (like it explains in the link).
Thanks Ned, I turned the very obvious option on, and got all the CPU and memory information up. Played a video from my iPhone, and the bloody thing didn't freeze up!
I played a few more, and it's fine now. I don't know what happened, because I haven't changed anything major. I will do more testing, but it seems that everything is fine now?
Cheers!
-Steve
