2012-10-24, 03:07
2012-10-24, 09:21
Better late than never
2012-10-09 Advanced Library Filtering
In general the advanced filtering replaces the title-based filtering and the two filtering mechanisms can't coexist in a view i.e. either title-based filtering will work or advanced filtering will work but never both. advanced filtering is available in library views showing movies, tvshows, episodes, musicvideos, artists, albums or songs. In any other view the old title-based filtering will still be available. So in general what skinners need to change is to add something like
to the old title-based filter control with id="19" to only show it when available.
Whether a skin wants to support advanced filtering is up to the skinner. If that's the case a new radiobutton control needs to be added (no specific ID required) and the <onclick> event should fire the new "Filter" action. Furthermore the previously listed info labels should be used to only show the button when advanced filtering is available. This is how it looks in confluence
- new dialog DialogMediaFilter.xml (very similar to DialogAddonSettings.xml)
- new control functionality "range slider" with two nibs to select a range
- new container info booleans:
- canfilter: true if simple title-based filtering is available, false if no or advanced filtering is available
- canfilteradvanced: true if advanced filtering is available, false otherwise
- filtered: true if any filter is active (whether title-based or advanced)
- new action "Filter" which will trigger whatever filtering is available in a view. In case of title-based filtering it will show an input box with the on-screen keyboard and in case of advanced filtering it will open the advanced filtering dialog
PHP Code:
<visible>Container.CanFilter + !Container.CanFilterAdvanced</visible>
PHP Code:
<control type="radiobutton" id="20">
<visible>Container.CanFilterAdvanced</visible>
<selected>Container.Filtered</selected>
<onclick>right</onclick>
<onclick>Filter</onclick>
</control>
2012-10-24, 13:28
Thanks Montellese for clarifying this.
Since i think many people (like me) would like the old title-based filtering method, IMHO the best way to do this is to add a setting (maybe in Appearance / File Lists settings screen) to enable/disable Advanced Filtering. No visible conditions, no new on-click action needed. The same button but with different action depending on the setting.
Of course skinners can do that in skin settings but i wish it will hardcoded to XBMC.
Cheers
Nessus
Cheers
Nessus
2012-10-24, 13:32
The advanced filtering can do title filtering as well (you can just ignore all the other filters) so I don't really see the advantage of a GUI setting. In addition we are trying hard to avoid any additional GUI settings which are not absolutely necessary because the more settings there are the more confusing it gets for users.
2012-10-24, 20:47
I am aware and i understand the intention of the team to avoid any additional GUI settings but... it never hurts to ask.
Nessus
Nessus
2012-10-26, 09:08
(2012-10-23, 16:23)Hitcher Wrote: [ -> ]There's something wrong with the double sliders in this new dialog - they don't animate if you press and hold left or right unlike the single ones.this was fixed by Montellese with https://github.com/xbmc/xbmc/pull/1661
2012-10-29, 19:25
What is the window ID for DialogMediaFilter.xml? Confluence seems to be using 151 which in the wiki is DialogExtendedProgressBar.xml.
-edit, thnx ronie-
-edit, thnx ronie-
2012-10-29, 19:34
(2012-10-29, 19:25)MassIV Wrote: [ -> ]What is the window ID for DialogMediaFilter.xml?
152
2012-10-30, 00:29
(2012-10-29, 19:34)ronie Wrote: [ -> ](2012-10-29, 19:25)MassIV Wrote: [ -> ]What is the window ID for DialogMediaFilter.xml?
152
Thats odd because in Application.cpp it says
Quote:@line 1286: g_windowManager.Add(new CGUIDialogMediaFilter); // window id = 151which means that DialogExtendedProgressBar is wrong in confluence and the other is right?
@line 1239: g_windowManager.Add(new CGUIDialogExtendedProgressBar); // window id = 148
btw I didn't add either window so I have no idea
2012-10-30, 00:35
(2012-10-30, 00:29)Jezz_X Wrote: [ -> ](2012-10-29, 19:34)ronie Wrote: [ -> ](2012-10-29, 19:25)MassIV Wrote: [ -> ]What is the window ID for DialogMediaFilter.xml?
152
nobody said our code is perfect ;-)
guilib/Key.h
#define WINDOW_DIALOG_EXT_PROGRESS 10151
#define WINDOW_DIALOG_MEDIA_FILTER 10152
2012-10-30, 01:24
Note that you should only really be using the name of the window, not it's id to reference things. I'll remove some of the comments floating around in the code so confusion doesn't happen again (Montellese has just fixed them all up, but better to just remove 'em).
I also strongly recommend you don't specify the id in the XML files - it's not read at all anyway, with the possible exception of custom windows.
If you want to add some documentation about the window, I'd suggest adding the window name in a comment or <description> tag.
2012-11-04, 16:03
(2012-06-02, 15:24)ronie Wrote: [ -> ]2012-06-02 Changed Infolabel
Container.TVShowThumb
Container.TVShowThumb can now also be used in the video info dialog
git commit: https://github.com/xbmc/xbmc/commit/84e4...4f7e3d157b
forum post: http://forum.xbmc.org/showthread.php?tid...pid1110513
This doesn't seem to work when in the recently added episodes node. Whereas ListItem.Property(TVShowThumb) would before. Any chance to remedy this?
2012-11-04, 16:33
2012-11-06, 05:10
(2012-10-24, 13:32)Montellese Wrote: [ -> ]The advanced filtering can do title filtering as well (you can just ignore all the other filters) so I don't really see the advantage of a GUI setting. In addition we are trying hard to avoid any additional GUI settings which are not absolutely necessary because the more settings there are the more confusing it gets for users.
It doesn't need a GUI setting in XBMC, but if a skinner chooses to add the option to the skin (like I just did for Metropolis, because I also prefer the old method), the standard filter should continue to work even if Container.CanFilterAdvanced is true. As it is now, it doesn't. Can this be changed?
2012-11-07, 18:33
2012-11-07 Alignment changes
Slight change in vertical font alignment
git commit: https://github.com/xbmc/xbmc/commit/f849...ed6cbc7138
pull request: 1703 (PR)
Remove hardcoded center of some settings controls
git commit: https://github.com/xbmc/xbmc/commit/ed9a...47fef71a49
pull request: 1713 (PR)
forum discussion: http://forum.xbmc.org/showthread.php?tid=144052
