Full Version: [XBMCbuntu]No wakeup from suspend
I just did a fresh install of Eden final. Everything is working so far except this wakeup issue.
But I kinda expected this because in Dharma I had this problem too always after a fresh install.
I've used until now the following Guide to solve the problem but it doesn't seem to work with eden.
I'm using a genuine MCE Remote with a non genuine RC6 receiver. Any Ideas how to solve this ?
The guide you linked to is now out-of-date as with newer kernels one has to enable both the USB port AND the device to enable wake-from-suspend.
There are details in here: http://forum.xbmc.org/showthread.php?tid=121767
(2012-03-25, 18:37)dnairb Wrote: [ -> ]The guide you linked to is now out-of-date as with newer kernels one has to enable both the USB port AND the device to enable wake-from-suspend.
Thx that was exactly what I needed.
After adding
echo enabled > /sys/bus/usb/devices/2-3/power/wakeup
to /etc/rc.local the wakeup issue resolved.
