I am on Eden RC2 and I noticed that now when I scrape the movies or TV shows that the media flags are not included. But, when I start the movie or TV shown then they appear.
I am sory if it's allready mentioned
(2012-03-25, 21:12)OggyHr Wrote: [ -> ]Hi,
That's because XBMC cannot read some video containers without playing them first.
.iso is an example of this
This is all .mkv or .avi. Before RC2 or maybe RC1 it was all good.
You cant see them until you played the file once or you cant see it in library mode but see them while playing the file?
If its the 2nd check your skin setting maybe you disabled mediaflags?
It's the first one. I must play the file once and then they are here. But, flag for Blue-Ray or folm studio are visible from the start. Other flags (aspect ratio, HD or HD ready, audio chanell, DTS or AC etc) are showned when I once played the file...
I find what's the problem. It's my setup...
I turned off option to extract video information from file (video settings-file list).
Sory for alarm
