hi everyone!i have a question about the subtitles addon...is there a way that we can put an extra source site like podnapisi so we can have extra subtitles?for example,greek sites with subtitles?
thank you and any help will be preciated!
Hello syllas,
This facility already exists since i am using it aswell.
First of all you have to go your add ons and find the subtitle and configure the languages to read. Then configure the add on to have sources the ones you desire.
If you need navigation help let me know.
Basically my problem if someone could shed some light is that i cant use the addon after upgrading to Eden.
My error log shows
21:11:19 T:2005834608 NOTICE: Opening Subtitle stream: 0 source: 1024
21:11:19 T:2005834608 ERROR: OpenStream - Unable to create subtitle parser
21:11:19 T:2005834608 WARNING: OpenSubtitleStream - Unsupported stream 0. Stream disabled.
21:11:20 T:7444240 ERROR: ClearBlock: Trying to clear non existent block /home/xbmc/.xbmc/addons/script.xbmc.subtitles
