2012-03-26, 01:11
In previous versions I've appreciated that I can run XBMC remotely, so as not to risk image retention or burn-in on my plasma TV when doing maintence work on my movie library.
The most recent release crashes during startup. Here's the log:
I have not changed the graphics card and it's got the same driver as before. I would appreciate it a lot if someone could help me out
23:07:17 T:4924 NOTICE: -----------------------------------------------------------------------
23:07:17 T:4924 NOTICE: Starting XBMC (11.0 Git:20120321-14feb09), Platform: Windows 7, 64-bit (WoW) build 7600. Built on Mar 21 2012 (compiler 1600)
23:07:17 T:4924 NOTICE: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
23:07:17 T:4924 NOTICE: Desktop Resolution: 1440x900 32Bit at 60Hz
23:07:17 T:4924 NOTICE: Running with restricted rights
23:07:17 T:4924 NOTICE: Aero is disabled
23:07:17 T:4924 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
23:07:17 T:4924 NOTICE: Setup SDL
23:07:17 T:4924 NOTICE: Found screen: Dummy Monitor on RDPDD Chained DD, adapter 0.
23:07:17 T:4924 NOTICE: Primary mode: 1440x900 @ 60.00 - Full Screen
23:07:17 T:4924 NOTICE: Additional mode: 1440x900 @ 60.00 - Full Screen
23:07:17 T:4924 NOTICE: load settings...
23:07:17 T:4924 NOTICE: special://profile/ is mapped to: special://masterprofile/
23:07:17 T:4924 NOTICE: loading special://masterprofile/guisettings.xml
23:07:17 T:4924 NOTICE: Getting hardware information now...
23:07:17 T:4924 NOTICE: Checking resolution 12
23:07:17 T:4924 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
23:07:17 T:4924 NOTICE: Loaded playercorefactory configuration
23:07:17 T:4924 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
23:07:17 T:4924 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
23:07:17 T:4924 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
23:07:17 T:4924 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
23:07:17 T:4924 NOTICE: Default DVD Player: dvdplayer
23:07:17 T:4924 NOTICE: Default Video Player: dvdplayer
23:07:17 T:4924 NOTICE: Default Audio Player: paplayer
23:07:17 T:4924 NOTICE: Disabled debug logging due to GUI setting. Level 0.
23:07:17 T:4924 NOTICE: Log level changed to 0
23:07:17 T:4924 NOTICE: Loading media sources from special://masterprofile/sources.xml
23:07:17 T:4924 NOTICE: Enabled Joystick: BD Remote Control
23:07:17 T:4924 NOTICE: Details: Total Axis: 0 Total Hats: 0 Total Buttons: 0
23:07:17 T:4924 WARNING: CRenderSystemDX::CreateDevice - initial wanted device config failed
23:07:17 T:4924 ERROR: CRenderSystemDX::CreateDevice - unable to create a device. 8876086C - D3DERR_INVALIDCALL (Invalid call)
23:07:17 T:4924 FATAL: CApplication::Create: Unable to init rendering system
23:07:19 T:640 ERROR: CRemoteControl::Connect - failed to connect
