Hi all,
when trying to access my time capsule from XBMC on iPad 2 5.0.1, i see my 'TCAPSULE' shared network resource however when i tap on it to access it I am getting an 'Operation not permitted' error. I am able to access from my XBMC on windows PC.
Also I am able to access any other network resources from my XBMC on my iPad.
anyone can help me figure out what is it that i'm doing wrong?
Yeah post a debug xbmc.log (first link in my signature).
(2012-03-26, 01:27)ssip96 Wrote: [ -> ]Hi all,
I had this same problem, but I found I could access the drive with my PC on. It was all down to what device was acting as the master browser, in my case it was my pc, after messing with some settings on my drive I got it going as the MB
Hopefully this is the same prob as I had, least it's something to look into
Looks like your TC is configured in a way where it needs some authentication data (e.x. username and password). You could try to add the source by hand in the form like:
smb://username:password@TCAPSULE/SharedFolder
Beside that i would recommend to use the IP of the TC instead of the TCAPSULE name.
(2012-03-27, 09:17)Memphiz Wrote: [ -> ]Looks like your TC is configured in a way where it needs some authentication data (e.x. username and password). You could try to add the source by hand in the form like:
Thank you.
Will try and post the results here.
Still an issue:
http://pastebin.com/AZf8iic1
(2012-03-27, 21:26)ssip96 Wrote: [ -> ] (2012-03-27, 09:17)Memphiz Wrote: [ -> ]Looks like your TC is configured in a way where it needs some authentication data (e.x. username and password). You could try to add the source by hand in the form like:
Still an issue:
Scratch that! Just had the wrong password. Got it to work! Thanks so much
What is considered the username? I have tried this smb://username:password@ipaddress/folder every way I can think of. All I get is "Operation not permitted"..."Couldn't retrieve directory information. This could be due to the network not being connected. Would you like to add it anyway?"
I had this working in Kodi 14.2 using crystalbuntu on my apple tv. I am using osmc with Kodi 16.1 now.
