2012-03-26, 14:32
I'm having smallish issues getting XBMCbuntu to work atm (WiFi works, LAN doesn't),
but I just wanted to check if I need to configure something in order to use XBMC Remote work with XBMCbuntu?
I use the app all the time on XBMC on Windows, but when I set it up on XBMCbuntu it didn't work.
It didn't connect at all, and I used same settings as on Windows. I didn't troubleshoot much on this, because my first prority is to get LAN working,
but if anyone knows anything about this, I'd be happy to get some advice for future reference
