I quit XBMC on my machine to launch the desktop of Ubuntu. I though I could easily adjust settings, but that cannot.
The problem I now have is that every time I reboot the desktop appears. I want to autostart XBMC (I selected that option in setup).
Which file do I need to edit to autostart XBMC and see the desktop never again??
it remembers what the last state was
if you reboot from desktop it will launch to desktop....if you reboot from xbmc it will launch xbmc
Logout from the desktop.
The login screen should appear. In the drop box, change it from XBMCbuntu to XBMC and log in.
(2012-03-26, 20:39)tweaker Wrote: [ -> ]Logout from the desktop.
Thanks, that seems to be the trick!
Not in my case - I have updated from Eden to Frodo Beta 2 yesterday and everything seemed to go fine.
Now it takes me to the desktop, too.
When I try to log in as xbmc user, the screen gets blank for a few seconds and the desktop login window appears again.
This is the crash log:
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Wed Dec 5 09:00:04 CET 2012
XBMC Options:
Arch: i686
Kernel: Linux 3.0.0-27-generic-pae #44-Ubuntu SMP Tue Oct 16 17:13:32 UTC 2012
Release:
Distributor ID: Ubuntu
Description: Ubuntu 11.10 - XBMCbuntu
Release: 11.10
Codename: oneiric
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
09:00:04 T:3021174544 NOTICE: -----------------------------------------------------------------------
09:00:04 T:3021174544 NOTICE: Starting XBMC (12.0-BETA2 Git:Unknown), Platform: Linux (Ubuntu 11.10 - XBMCbuntu, 3.0.0-27-generic-pae i686). Built on Dec 2 2012
09:00:04 T:3021174544 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
09:00:04 T:3021174544 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
09:00:04 T:3021174544 NOTICE: special://masterprofile/ is mapped to: /home/xbmc/.xbmc/userdata
09:00:04 T:3021174544 NOTICE: special://home/ is mapped to: /home/xbmc/.xbmc
09:00:04 T:3021174544 NOTICE: special://temp/ is mapped to: /home/xbmc/.xbmc/temp
09:00:04 T:3021174544 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
09:00:04 T:3021174544 NOTICE: Local hostname: HTPC
09:00:04 T:3021174544 NOTICE: Log File is located: /home/xbmc/.xbmc/temp/xbmc.log
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
And the xbmc.log:
And finally the .xsession-errors file:
Running X session wrapper
Loading profile from /etc/profile
Loading profile from /home/xbmc/.profile
Loading resource: /etc/X11/Xresources/x11-common
Loading X session script /etc/X11/Xsession.d/20x11-common_process-args
Loading X session script /etc/X11/Xsession.d/30x11-common_xresources
Loading X session script /etc/X11/Xsession.d/40x11-common_xsessionrc
Loading X session script /etc/X11/Xsession.d/50x11-common_determine-startup
Loading X session script /etc/X11/Xsession.d/52libcanberra-gtk3-module_add-to-gtk-modules
Loading X session script /etc/X11/Xsession.d/60x11-common_localhost
Loading X session script /etc/X11/Xsession.d/60x11-common_xdg_path
Loading X session script /etc/X11/Xsession.d/70gconfd_path-on-session
Loading X session script /etc/X11/Xsession.d/75dbus_dbus-launch
Loading X session script /etc/X11/Xsession.d/90consolekit
Loading X session script /etc/X11/Xsession.d/90x11-common_ssh-agent
Loading X session script /etc/X11/Xsession.d/99x11-common_start
/usr/lib/xbmc/xbmc-xrandr: Failed to get size of gamma for output default
Segmentation fault
Crash report available at /home/xbmc/xbmc_crashlog-20121205_090002.log
Segmentation fault
Crash report available at /home/xbmc/xbmc_crashlog-20121205_090003.log
Segmentation fault
Crash report available at /home/xbmc/xbmc_crashlog-20121205_090004.log
XBMC has exited uncleanly 3 times in the last 3 seconds.
Something is probably wrong
Nice message at the end...
EDIT: I have started a new
thread.
