Ok.
Im about to add a 2TB hdd to my XBMC filled with over 1200 movies.
Now, im sure it wont find 100% of them so im wondering if there is a way to just display the ones that it cant find maybe?
So then this way I can go back and rename those?
Anyone know of a way to do this?
Sure, once they're scanned in just browse from Files. Any it doesn't find won't have metadata attached.
There is also a missing movie plugin that will scan your files.
See the add-on section for the Eden version
Ahh very cool thanks!
Ill check that plug in as well!
These are dvd .iso files so how does one see if metadata is attached to the file or not? Thanks!!!
fantastic exactly what im looking for! What a great community here! The GF and i LOVE the xbmc!! All the hard work is appreciated!
One last question if you all dont mind.
She is using her laptop upstairs and has it hooked up to the TV via HDMI as a second display (macbook) How can you get XBMC to run in full screen on the SECOND monitor (TV)
Thanks all!
If your graphics drivers are set up for two monitors go to Settings>Video Output>Display Mode and select Full Screen #2.
AHHHHHHHHHHHH Ill try that tonight! Thanks your hard work is impressive and appreciated!
