Full Version: Additional HD Sound options
Hi
I've just grabbed the final version of Eden and upon starting it up for the first time, I noticed that the audio playback options screen is missing certain options that were available on the Eden RC 2 HDAudio setup. http://forum.xbmc.org/showthread.php?tid...pid1008591
http://i40.tinypic.com/119vvvt.jpg
Is there a way to incorporate the above, or will it be a case of just waiting for the developer of the alternative exe to update to the final Eden?
Wiggo
Edit: A new updated version has been released.
The HD audio is a patch and is so far not into the mainline xbmc releases. Either you can wait until it has been incorporated via the patch (here: http://forum.xbmc.org/showthread.php?tid=121877 ) or go back to the RC2 version.
Edit: it appears it has been released in that thread. http://dl.dropbox.com/u/25170804/XBMCSet...nfinal.exe may be some problems with it though I'd check that thread.
(2012-03-27, 10:15)deanmv Wrote: [ -> ]The HD audio is a patch and is so far not into the mainline xbmc releases. Either you can wait until it has been incorporated via the patch (here: http://forum.xbmc.org/showthread.php?tid=121877 ) or go back to the RC2 version.
Thanks for your reply.
I've just grabbed it now and all seems ok. I must be one of the lucky ones Smile
Wiggo
