Full Version: Can't Play some BD file
and when open the library , The xbmc be crash.
At archlinux ,the newest git version(8ca8fdacbd)
20:36:36 T:2651016000   DEBUG: CDVDInputStreamBluray - Opening file /media/G/Le.Cercle.Rouge.1970 [BD]/BDMV/CLIPINF/00033.clpi... (0xa3c94cf8)
20:36:36 T:2651016000   DEBUG: CDVDInputStreamBluray - Closed file (0xa3c94cf8)
20:36:36 T:2651016000   DEBUG: CDVDInputStreamBluray - Opening file /media/G/Le.Cercle.Rouge.1970 [BD]/BDMV/STREAM/00017.m2ts... (0xb250c418)
20:36:36 T:2651016000   DEBUG: Open - probing detected format [mpegts]
20:36:36 T:2651016000   DEBUG: Open - av_find_stream_info starting
20:36:36 T:2651016000   DEBUG: ffmpeg[9E034B40]: [mpegts] Estimating duration from bitrate, this may be inaccurate
20:36:36 T:2651016000   DEBUG: Open - av_find_stream_info finished
20:36:36 T:2651016000    INFO: ffmpeg[9E034B40]: Input #0, mpegts, from '':
20:36:36 T:2651016000    INFO: ffmpeg[9E034B40]:   Duration: N/A, bitrate: N/A
20:36:36 T:3007793728   ERROR: CWinSystemX11::XErrorHandler: BadDrawable (invalid Pixmap or Window parameter), type:0, serial:228, error_code:9, request_code:138 minor_code:12
20:36:36 T:3007793728   ERROR: CWinSystemX11::XErrorHandler: BadDrawable (invalid Pixmap or Window parameter), type:0, serial:229, error_code:9, request_code:138 minor_code:12
20:36:36 T:3007793728   ERROR: CWinSystemX11::XErrorHandler: BadDrawable (invalid Pixmap or Window parameter), type:0, serial:230, error_code:9, request_code:138 minor_code:12
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
21:06:56 T:2548038464   DEBUG: CDVDInputStreamBluray - Opening file /media/G/Orfeu Negro(1959)/BDMV/STREAM/00236.m2ts... (0xaae40560)
21:06:56 T:2548038464   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avcore-0-i486-linux.so)
21:06:56 T:2548038464   DEBUG: Loading: /usr/lib/xbmc/system/players/dvdplayer/avcore-0-i486-linux.so
21:06:56 T:2548038464   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avcodec-52-i486-linux.so)
21:06:56 T:2548038464   DEBUG: Loading: /usr/lib/xbmc/system/players/dvdplayer/avcodec-52-i486-linux.so
21:06:56 T:2548038464   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avformat-52-i486-linux.so)
21:06:56 T:2548038464   DEBUG: Loading: /usr/lib/xbmc/system/players/dvdplayer/avformat-52-i486-linux.so
21:06:56 T:2548038464   DEBUG: Open - probing detected format [mpegts]
21:06:56 T:3007609408   DEBUG: SDLKeyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
21:06:56 T:3007609408   DEBUG: OnKey: down (f081) pressed, action is Down
21:06:56 T:2548038464   DEBUG: Open - av_find_stream_info starting
21:06:56 T:2548038464   DEBUG: ffmpeg[97DFFB40]: [mpegts] Estimating duration from bitrate, this may be inaccurate
21:06:56 T:2548038464   DEBUG: Open - av_find_stream_info finished
21:06:56 T:2548038464    INFO: ffmpeg[97DFFB40]: Input #0, mpegts, from '':
21:06:56 T:2548038464    INFO: ffmpeg[97DFFB40]:   Duration: N/A, bitrate: N/A
21:06:56 T:3007609408   ERROR: GetDirectory - Error getting /media/G/Orfeu Negro(1959)/BDMV/extrafanart/
