Full Version: XBMC and ReplayTV 5508 - XBMC hangs when trying to play videos
I have XBMC on both my XBOX1 and my PC (running Windows 7 64bit, 4gb RAM, latest XBMC). I can add my ReplayTV 5508 (rtv://192.168.X.XX) as a source no problem, and even browse the videos on it. But when I play it, XBMC just hangs.
Does anyone know what I can do to get my ReplayTV videos working on XBMC?
Thank you!
Need more info. What version of XBMC are you running on the PC?
XBMC 11.0 Beta 2
again, this problem also happens on my XBOX1 (which has XBMC4XBOX - don't know the version)
We don't support xbmc4xbox here
Update to XBMC v11 final and see if you still have the problem on your PC.
(2012-03-28, 00:04)Ned Scott Wrote: [ -> ]We don't support xbmc4xbox here
Still exists no matter what version of XBMC I have on my PC. Oh and I tried it with another PC with the same version, but same thing...
could you post a debug log?
I have a problem when I try to browse my ReplayTV, XBMC just crashes out on my ReplayTV 4500 series, BTW, dvarchive works fine with the unit. Debug log below:
08:10:05 T:139668380665728  NOTICE: Enabled debug logging due to GUI setting. Level 2.
08:10:05 T:139668380665728   DEBUG: ------ Window Init () ------
08:10:16 T:139668380665728   DEBUG: SDLKeyboard: scancode: 09, sym: 001b, unicode: 001b, modifier: 0
08:10:16 T:139668380665728   DEBUG: OnKey: escape (f01b) pressed, action is PreviousMenu
08:10:16 T:139668380665728   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
08:10:16 T:139668380665728   DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
08:10:16 T:139668380665728   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
08:10:16 T:139668380665728   DEBUG: ------ Window Init (Settings.xml) ------
08:10:16 T:139668380665728    INFO: Loading skin file: Settings.xml
08:10:18 T:139668380665728   DEBUG: SDLKeyboard: scancode: 09, sym: 001b, unicode: 001b, modifier: 0
08:10:18 T:139668380665728   DEBUG: OnKey: escape (f01b) pressed, action is PreviousMenu
08:10:18 T:139668380665728   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
08:10:18 T:139668380665728   DEBUG: ------ Window Deinit (Settings.xml) ------
08:10:18 T:139668380665728   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
08:10:18 T:139668380665728   DEBUG: ------ Window Init (Home.xml) ------
08:10:18 T:139668380665728    INFO: Loading skin file: Home.xml
08:10:19 T:139668380665728   DEBUG: SDLKeyboard: scancode: 71, sym: 0114, unicode: 0000, modifier: 0
08:10:19 T:139668380665728   DEBUG: OnKey: left (f082) pressed, action is Left
08:10:20 T:139668380665728   DEBUG: SDLKeyboard: scancode: 71, sym: 0114, unicode: 0000, modifier: 0
08:10:20 T:139668380665728   DEBUG: OnKey: left (f082) pressed, action is Left
08:10:21 T:139668380665728   DEBUG: SDLKeyboard: scancode: 71, sym: 0114, unicode: 0000, modifier: 0
08:10:21 T:139668380665728   DEBUG: OnKey: left (f082) pressed, action is Left
08:10:21 T:139667967973120   DEBUG: Thread Jobworker start, auto delete: 1
08:10:23 T:139668380665728   DEBUG: SDLKeyboard: scancode: 71, sym: 0114, unicode: 0000, modifier: 0
08:10:23 T:139668380665728   DEBUG: OnKey: left (f082) pressed, action is Left
08:10:25 T:139668380665728   DEBUG: SDLKeyboard: scancode: 71, sym: 0114, unicode: 0000, modifier: 0
08:10:25 T:139668380665728   DEBUG: OnKey: left (f082) pressed, action is Left
08:10:26 T:139668380665728   DEBUG: SDLKeyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
08:10:26 T:139668380665728   DEBUG: OnKey: down (f081) pressed, action is Down
08:10:26 T:139668380665728   DEBUG: SDLKeyboard: scancode: 72, sym: 0113, unicode: 0000, modifier: 0
08:10:26 T:139668380665728   DEBUG: OnKey: right (f083) pressed, action is Right
08:10:27 T:139668380665728   DEBUG: SDLKeyboard: scancode: 24, sym: 000d, unicode: 000d, modifier: 0
08:10:27 T:139668380665728   DEBUG: OnKey: return (f00d) pressed, action is Select
08:10:27 T:139668380665728   DEBUG: ExecuteXBMCAction : Translating ActivateWindow(Videos,Files,return)
08:10:27 T:139668380665728   DEBUG: ExecuteXBMCAction : To ActivateWindow(Videos,Files,return)
08:10:27 T:139668380665728   DEBUG: Activating window ID: 10025
08:10:27 T:139668380665728   DEBUG: ------ Window Deinit (Home.xml) ------
08:10:27 T:139668380665728   DEBUG: ------ Window Init (MyVideoNav.xml) ------
08:10:27 T:139668380665728    INFO: Loading skin file: MyVideoNav.xml
08:10:27 T:139668380665728   DEBUG: CGUIMediaWindow::GetDirectory (sources://video/)
08:10:27 T:139668380665728   DEBUG:   ParentPath = [sources://video/]
08:10:27 T:139667959580416   DEBUG: Thread Background Loader start, auto delete: 0
08:10:27 T:139667959580416   DEBUG: Thread Background Loader 139667959580416 terminating
08:10:28 T:139668380665728   DEBUG: SDLKeyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
08:10:28 T:139668380665728   DEBUG: OnKey: down (f081) pressed, action is Down
08:10:29 T:139668380665728   DEBUG: SDLKeyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
08:10:29 T:139668380665728   DEBUG: OnKey: down (f081) pressed, action is Down
08:10:29 T:139668380665728   DEBUG: SDLKeyboard: scancode: 6f, sym: 0111, unicode: 0000, modifier: 0
08:10:29 T:139668380665728   DEBUG: OnKey: up (f080) pressed, action is Up
08:10:30 T:139668380665728   DEBUG: SDLKeyboard: scancode: 6f, sym: 0111, unicode: 0000, modifier: 0
08:10:30 T:139668380665728   DEBUG: OnKey: up (f080) pressed, action is Up
08:10:32 T:139668380665728   DEBUG: SDLKeyboard: scancode: 24, sym: 000d, unicode: 000d, modifier: 0
08:10:32 T:139668380665728   DEBUG: OnKey: return (f00d) pressed, action is Select
08:10:32 T:139668380665728   DEBUG: CGUIMediaWindow::GetDirectory (rtv://192.168.1.20/)
08:10:32 T:139668380665728   DEBUG:   ParentPath = [sources://video/]
The above post is when I use my ReplayTV's IP in as a source, but if I just use
<source>
<name>ReplayTV</name>
<path>rtv://*/</path>
</source>
then it just hangs. Debug log for this is:
08:15:37 T:140338083612544   DEBUG: SDLKeyboard: scancode: 24, sym: 000d, unicode: 000d, modifier: 0
08:15:37 T:140338083612544   DEBUG: OnKey: return (f00d) pressed, action is Select
08:15:37 T:140338083612544   DEBUG: CGUIMediaWindow::GetDirectory (rtv://*/)
08:15:37 T:140338083612544   DEBUG:   ParentPath = [sources://video/]
08:15:37 T:140338083612544   DEBUG: ------ Window Init (DialogBusy.xml) ------
08:15:52 T:140338083612544   DEBUG: SECTION:UnloadDelayed(DLL: libcrystalhd.so.3)
08:15:52 T:140338083612544   DEBUG: Unloading: libcrystalhd.so.3
08:15:53 T:140338083612544    INFO: LIRC Initialize: using: /dev/lircd
08:15:53 T:140338083612544   DEBUG: Failed to connect to LIRC. Retry in 40s.
08:15:53 T:140338083612544   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-x86_64-linux.so)
08:15:53 T:140338083612544   DEBUG: Unloading: ImageLib-x86_64-linux.so
08:15:53 T:140338083612544    INFO: CheckIdle - Closing session to http://api.themoviedb.org (easy=0x7fa2ec0ec160, multi=0x7fa2ec0a4070)
08:16:07 T:140337443989248   DEBUG: Thread Jobworker 140337443989248 terminating (autodelete)
08:16:07 T:140337619240704   DEBUG: Thread Jobworker 140337619240704 terminating (autodelete)
08:16:07 T:140337636595456   DEBUG: Thread Jobworker 140337636595456 terminating (autodelete)
08:16:33 T:140338083612544    INFO: LIRC Initialize: using: /dev/lircd
08:16:33 T:140338083612544   DEBUG: Failed to connect to LIRC. Giving up.
I hope someone finds a fix for this...
