I am having an issue with the improper movie/program info being displayed. Basically I have seasons of the show Breaking Bad, yet it forces the name & all info to change to a movie called The Bad News Bears in Breaking Training! LOL I downloaded XWMM, so I can edit the info & it works, but for over 50 files is extremely time consuming. Is there a better way of updating all of these? Possibly using the proper info from IMDB?
Thanks all!
What have you set your scraper to? It sounds like you are using a movie scraper on a source that should be set to a tv show scraper.
Yeah, I think I have it set to IMDB, can I set to both, as I have movies & TV shows mixed on the network drive I have it pointed to...
Is breaking bad in it's own folder? If so, from videos just set content on that specific folder to TV shows. I believe that should work but I separate my movies and shows to separate paths.
If all your content is just in one large folder then you are most likely out of luck.
It's HIGHLY recommended to separate TV shows and movies.
