Full Version: Help! Xbmcbuntu - bootmgr missing - Ctrl+Alt+Del to restart #1
Hey All,
If i try to boot with xbmcbuntu (The new xbmclive) i get the error that bootmgr is missing - press ctrl+alt+del to reboot.
Eveyrthing ive read says i need to run startup repair - well i did that - it finds no errors , windows does boot fine if i dont try xbmcbuntu , however i really want to toy around with it and im confused as to why it wont boot.
Anyone have any ideas?
I can boot cd's / Windows on a usb key - or the windows i have installed without problems.
Problem is that its a netbook and it wont run xbmc properly with windows so id like to try it without the OS.
Thank in advance!
Btw - downloaded buntu from : http://xbmc.org/download/ and i used the guide on wiki - by using unetbootin to put the iso on the usb key after formatting it
I tried all the steps here : http://support.microsoft.com/kb/2622803
option 1 fnds no errors - option 2 from dos prompt did go through and said successful , yet still i cant boot xbmcbuntu
getting the same error with that cd
so, did you find the solution?
i tried as this website said
they told me to fix my pc by using startup repair
and they said
"Select your windows version and click on next to start windows startup repair by using your windows disc."
but my windows not listed there so, what can do for thatHuh
