(2012-03-30, 15:47)DLeavy Wrote: [ -> ]Is it just this one file? Can you post the mediainfo of the file?
No, not only that file. All AVI file has the same problem.
Here is the mediainfo:
General
Complete name : E:\TV show\Shaun the sheep\Shaun - The Sheep - Season 1\Shaun.The.Sheep.S01E02.Bathtime (thecodeishere).avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 106 MiB
Duration : 7mn 1s
Overall bit rate : 2 117 Kbps
Writing library : TMPGEnc 4.0 XPress Version. 4.2.3.193
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Custom
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 7mn 1s
Bit rate : 1 917 Kbps
Width : 960 pixels
Height : 540 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.148
Stream size : 96.4 MiB (91%)
Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 7mn 1s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 9.66 MiB (9%)
Alignment : Split accross interleaves
Interleave, duration : 250 ms (6.25 video frames)
Interleave, preload duration : 229 ms
