Full Version: Neon skin - image scraper
I am fairly new to XBMC and I just started playing with the Neon skin last night. I'm just wondering if the skin will download all of the images for every view or if I need to add a different scraper for certain views. I didn't completely finish updating last night, but I noticed after a little bit of time that the TV shows were mostly updated and the logos (clearArt) were missing and some of the sizes seemed off for the specific view I liked. Basically, are most of the skins set up or designed to grab all of the images for the views they support or is this something the user has to do?
There is an option under settings > skin to download the various images all at once, based on type. I.E., you can download all of the banners.jpg and then all of the clearart.jpg, etc.
Great! I will look into that. Thanks for the response, really liking this skin.
