Thanks d1dd1 much appreciated.
(2012-06-17, 09:42)Ribuck Wrote: [ -> ]Hi brokencodes, Ideally hdmi output at 1080p in PAL format but i thout it was only supporting 720p. Also what tools are people using to edit the bin fle to change resolutions etc, outputs etc ?
Out of interest what are you doing differently to make it boot from SD for ics image ?? Was I supposed to prep the SD card in some special way for the ics beta image ?
Many thanks,
Ribuck
You use bin2fex to convert the bin file to a fex file, which you edit with a text editor, then you use fex2bin to convert it back to bin file, which you then place on the sdcard using the same filename as the one already there...
What is needed in order to bring GPU Acceleration to X-Server? mali.ko?
Its probably a lot more complicated than that.
(2012-06-17, 22:13)Ribuck Wrote: [ -> ]Well i phoneixcard just stops responding for me and i get a "failed 1075!" error message what ever that means. Guess it doesn't like my laptop.
if anyone has a copy of the phoenixcard from the the mele1.6.rar file could they upload it somewhere for me please, as the downloading is mega slow and saying the mele1.6 rar file will take 2 hours.......
Phoenixcard is useless with internal cardreader of your laptop. you can only do with external card reader and dont forget to disable your internal cardreader from windows device manager.
(2012-06-18, 04:52)chandankp Wrote: [ -> ]Phoenixcard is useless with internal cardreader of your laptop. you can only do with external card reader and dont forget to disable your internal cardreader from windows device manager.
For me it works with the internal cardreader of the laptop.
I rebuilt my windows7 laptop, and PhoenixCard worked perfectly after that with the internal card reader.
Does this new ICS image support GPU acceleration ?
When did this become a support thread about flashing Android 4.0 ICS firmware onto Male 1000/2000 and why?
Thread-jack much? Flashing the Android 4.0 ICS firmware onto Male 1000/2000 has nothing to do with XBMC!
Even if XBMC ran on Android, this is still not a Male 1000/2000 firmware flashing support thread or forum
Sorry, you're right, I just wanted to help.
So, btt...
RockerC, to be fair i complained about this ages ago, many pages back when people were talking about buying hardware and was told by an XBMC admin that people talking about buying kit was acceptable so i think think the thread lost it's way a long time ago.........
That said i do agree, that this thread should only be about mali gpu supports in xbmc, so I apologize for my recent threads that weren't really relevant to this thread, as i know that it initially bugged me too.
