2012-09-26, 17:33
The VPU does the decoding, after that someone has to render it, both the VPU and the GPU can do it, in the empatzero source Mali is doing it.
(2012-09-26, 16:54)Shivansps Wrote: [ -> ]Well dvdplayer is rendering on Mali, thats why is slow, and if you have a 720P resoution there should be no diferences in a 1080P or 720P movie.
Im still wondering about the "jumping"... ill have to use 720P hdmi resolution and try...
(2012-09-26, 21:49)halfe Wrote: [ -> ]Ehm.. I'm really new at this forum but been searching this forum for XBMC support for allwinner A10 and i found this thread.
started reading but found out that this is to much to read. how far have the development of the Video Hardware acceleration for the XBMC come.
I found a link
MK802, XBMC dead in waters
is this true?
also found this
im really interested in XBMC release for this mini PC since other players have problems running 720p 1080p HW.
(2012-09-26, 17:11)gimli Wrote: [ -> ](2012-09-26, 17:08)Shivansps Wrote: [ -> ]Well we cant expect a Mali-400 single core to have enoght power to render a 30fps 1080P movie (it can barely render the UI at a not so decent fps). Im not even sure that the Broadcom GPU on the Raspi will be able to do so...
Thats what you think.
(2012-09-26, 23:33)fmarcos Wrote: [ -> ]Errm, AppleTV? Its Mali-400 correct?(2012-09-26, 17:11)gimli Wrote: [ -> ](2012-09-26, 17:08)Shivansps Wrote: [ -> ]Well we cant expect a Mali-400 single core to have enoght power to render a 30fps 1080P movie (it can barely render the UI at a not so decent fps). Im not even sure that the Broadcom GPU on the Raspi will be able to do so...
Teaser! Man, I bet Gimli has something amazing up his sleves...
(2012-09-27, 06:56)wizziwig Wrote: [ -> ]I think the build you guys are testing uses a texture to store the decoded video frames which are then rendered on a full-screen quad using the Mali. This is not the correct way to display video on low-power Android devices. Their GPU's are way too slow for that, especially combined with a complex alpha blended UI like XBMC. Not even Tegra3 could manage that at 1080p @60hz. The VPU needs to directly decode frames to a hardware overlay surface which is displayed directly without any copies/yuv conversion or GPU rendering involved. The GPU can then render the UI at 20 fps without interfering/blocking full FPS video displayed asynchronously in the background. This is how all the Android hardware accelerated players work. I suspect it was easier to get working with textures in Linux.
(2012-09-27, 07:51)gimli Wrote: [ -> ]Ok then we should substitute the row 255 of DVDVideoCodecA10.cpp:(2012-09-27, 06:56)wizziwig Wrote: [ -> ]I think the build you guys are testing uses a texture to store the decoded video frames which are then rendered on a full-screen quad using the Mali. This is not the correct way to display video on low-power Android devices. Their GPU's are way too slow for that, especially combined with a complex alpha blended UI like XBMC. Not even Tegra3 could manage that at 1080p @60hz. The VPU needs to directly decode frames to a hardware overlay surface which is displayed directly without any copies/yuv conversion or GPU rendering involved. The GPU can then render the UI at 20 fps without interfering/blocking full FPS video displayed asynchronously in the background. This is how all the Android hardware accelerated players work. I suspect it was easier to get working with textures in Linux.
Correct.
m_yuvdata = (u8*)mem_palloc(ysize + csize, 1024);
(2012-09-27, 18:14)Shivansps Wrote: [ -> ]What im not sure is what "RealVideo" means in libve... Realvideo 7? 8? 9? 10RealVideo 1.0 and RealVideo G2 (FourCC: rv10 and rv20) codec used in RealPlayer 6 and 7 was based on H.263, so it was not until the release of RealVideo 8/9/10 (FourCC: rv30 and rv40) that came with RealPlayer 8/9/10 respectivly that they based their video codec on H.264
(2012-09-27, 18:14)Shivansps Wrote: [ -> ]Also Cedar has support for some codecs i never heard of... SORENSSON_H263?SORENSSON_H263 = Sorenson Spark, which is basically an incomplete implementation of H.263, and much Flash Video content (as used on sites such as YouTube, Google Video, MySpace, etc.) used to be encoded in Sorenson Spark format before most of them switched to using VP6 or H.264 encoding that they have today.
(2012-09-27, 18:14)Shivansps Wrote: [ -> ]im not even sure why they wasted time to add H263, MSMPEGV1/2/3 support at all, I consider H263 deprecated as well, so is WMV1/2While the H.263 encoding standard is today considered a legacy design, ISO MPEG-4 is H.263 compatible in the sense that a basic H.263 bitstream is correctly decoded by an ISO MPEG-4 video decoder, so I guess they might just trow that in decoding of all H.263 codecs for free since they would only have to pay for the license once and be able to decode all of those.
