right if i plug the rc6 reciever into the windows pc, shoykey doesnt show anything, its working because if i press some buttons on my mce remote it picks them up.
Matt
(2012-03-30, 18:06)jhsrennie Wrote: [ -> ]If you enable debug logging from System settings, System, Debugging, then press the volume buttons a few times the log will show what signals XBMC is receiving, and from that you can work out what to change in the keyboard.xml.
See http://wiki.xbmc.org/index.php?title=Log_File#Location for how to get at the debug log, though I'm not sure how you'd get the logg off a Live installation.
JR
i think this is the relevent bit...
17:41:19 T:14588160 DEBUG: Previous line repeats 32 times.
17:41:19 T:14588160 DEBUG: SDLKeyboard: scancode: 13, sym: 0030, unicode: 0030, modifier: 0
17:41:19 T:14588160 DEBUG: OnKey: zero (f030) pressed, action is Number0
17:41:19 T:14588160 DEBUG: Error: Requested setting (pvrplayback.signalquality) was not found. It must be case-sensitive
17:41:20 T:3029334896 DEBUG: Previous line repeats 1 times.
17:41:20 T:3029334896 WARNING: CDVDPlayer::CheckContinuity - wrapback of stream:1, prev:5773147000.000000, curr:5773099000.000000, diff:-48000.000000
17:41:20 T:14588160 DEBUG: Error: Requested setting (pvrplayback.signalquality) was not found. It must be case-sensitive
17:41:21 T:3029334896 DEBUG: Previous line repeats 31 times.
17:41:21 T:3029334896 WARNING: CDVDPlayer::CheckContinuity - wrapback of stream:1, prev:5774523000.000000, curr:5774475000.000000, diff:-48000.000000
17:41:21 T:14588160 DEBUG: Error: Requested setting (pvrplayback.signalquality) was not found. It must be case-sensitive
17:41:21 T:14588160 DEBUG: Previous line repeats 6 times.
17:41:21 T:14588160 DEBUG: SDLKeyboard: scancode: 13, sym: 0030, unicode: 0030, modifier: 0
17:41:21 T:14588160 DEBUG: OnKey: zero (f030) pressed, action is Number0
17:41:22 T:14588160 DEBUG: Previous line repeats 21 times.
17:41:22 T:14588160 DEBUG: SDLKeyboard: scancode: 13, sym: 0030, unicode: 0030, modifier: 0
17:41:22 T:14588160 DEBUG: OnKey: zero (f030) pressed, action is Number0
17:41:22 T:14588160 DEBUG: Error: Requested setting (pvrplayback.signalquality) was not found. It must be case-sensitive
17:41:22 T:2881575792 DEBUG: CPullupCorrection: detected pattern of length 1: 41708.33, frameduration: 41708.333333
17:41:23 T:14588160 DEBUG: Previous line repeats 23 times.
17:41:23 T:14588160 DEBUG: SDLKeyboard: scancode: 32, sym: 0130, unicode: 0000, modifier: 0
17:41:23 T:14588160 DEBUG: OnKey: leftshift (f0d2) pressed, action is
17:41:23 T:14588160 DEBUG: SDLKeyboard: scancode: 0c, sym: 0033, unicode: 00a3, modifier: 1
17:41:23 T:14588160 DEBUG: OnKey: three (f033) pressed, action is Number3
17:41:23 T:14588160 DEBUG: Error: Requested setting (pvrplayback.signalquality) was not found. It must be case-sensitive
17:41:24 T:3029334896 DEBUG: Previous line repeats 11 times.
17:41:24 T:3029334896 WARNING: CDVDPlayer::CheckContinuity - wrapback of stream:1, prev:5777275000.000000, curr:5777227000.000000, diff:-48000.000000
17:41:24 T:14588160 DEBUG: Error: Requested setting (pvrplayback.signalquality) was not found. It must be case-sensitive
17:41:24 T:14588160 DEBUG: Previous line repeats 6 times.
17:41:24 T:14588160 DEBUG: SDLKeyboard: scancode: 32, sym: 0130, unicode: 0000, modifier: 0
17:41:24 T:14588160 DEBUG: OnKey: leftshift (f0d2) pressed, action is
17:41:24 T:14588160 DEBUG: SDLKeyboard: scancode: 0c, sym: 0033, unicode: 00a3, modifier: 1
17:41:24 T:14588160 DEBUG: OnKey: three (f033) pressed, action is Number3
17:41:25 T:14588160 DEBUG: Previous line repeats 22 times.
17:41:25 T:14588160 DEBUG: SDLKeyboard: scancode: 32, sym: 0130, unicode: 0000, modifier: 0
17:41:25 T:14588160 DEBUG: OnKey: leftshift (f0d2) pressed, action is
17:41:25 T:14588160 DEBUG: SDLKeyboard: scancode: 0c, sym: 0033, unicode: 00a3, modifier: 1
17:41:25 T:14588160 DEBUG: OnKey: three (f033) pressed, action is Number3
i pressed volume up 3 times and volume down 3 times, it appears its reporting as 0 and 3.
ive removed this section from the fullscreenvideo part of my remote.xml
<zero>Number0</zero>
<one>Number1</one>
<two>Number2</two>
<three>Number3</three>
<four>Number4</four>
<five>Number5</five>
<six>Number6</six>
<seven>Number7</seven>
<eight>Number8</eight>
<nine>Number9</nine>
and it makes no difference
Matt
