Full Version: Cannot login to trac
I just registered the forum because I found a bug in the database upgrade procedure from Dharma to Eden but I cannot login to trac...(I took the "case-sensitive" warning into account)
As you can see there is no problem for me to login to the forum.
Does anybody have an idea?
Thanks in advance
Should be all fixed now - thx to TheUni.
It is ok now.
