2012-03-29, 17:12
Hello! I'm treying to do something in the Home menu, concerning the Recently Added and the use of <visible> tag on the Home menu in the upcoming version of Shade 2.4.0.
Here's some image describing what happens, so it's easier to understand :
So, you're on "Movies", Recently added and featured items appear.
When you go on the Featured or recently added items, the top bar and icons disappear (through a <visible>!Control.HasFocus(8005)+!Control.HasFocus(8006)</visible> conditions, where 8005 and 8006 are the ID of the recently and featured lists), and Plot, Title, rating ,etc appears
When I press "up" from Featured (<onup>9000</onup> in 8005 is set to 9000, the list of icons in Home.xml), the focus goes directly on the submenu "options" of movies "Genres", "Years", etc... and not on "Movies" where it should logically goes....!
Do you have any ideas ho one could do it so that the focus goes on Movies, which is the case when the top menu doesn't disappear?
Thanks a lot for any help!
