Full Version: XBMC Eden RC2 + AEON MQ3 = Freezes
hi guys. I have the Xbmc Eden Rc2 with Audio HD and Aeon Mq3 Skin. The XBMC freeze then i go back the movie menu and freezes too then the screen saver (sideshow) starts. Other Skins runs well. I have uninstall the XBMC and install again, the skins, i clean the Users XBMC and install clean, and noting solve this problems. Sometimes then i go back to the main menu, is work, but, next time in same season is freeze.
The log:
20:11:12 T:6188 NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:11:12 T:6188 NOTICE: Log level changed to 0
20:11:12 T:6188 NOTICE: Loading media sources from special://masterprofile/sources.xml
20:11:14 T:4536 ERROR: CRemoteControl::Connect - failed to connect
20:11:14 T:6188 NOTICE: initializing playlistplayer
20:11:14 T:6188 NOTICE: DONE initializing playlistplayer
20:11:15 T:6572 NOTICE: -->Python Interpreter Initialized<--
20:11:15 T:6572 NOTICE: downloader ARGV: ['']
20:11:15 T:1212 NOTICE: -->Python Interpreter Initialized<--
20:11:15 T:6188 NOTICE: initialize done
20:11:15 T:6188 NOTICE: Running the application...
20:11:15 T:6188 NOTICE: ES: Starting event server
20:11:15 T:2416 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
20:11:15 T:2416 NOTICE: UDP: Listening on port 9777
20:11:15 T:6188 ERROR: Control 1 in window 10099 has been asked to focus, but it can't
20:11:15 T:4092 NOTICE: -->Python Interpreter Initialized<--
20:11:15 T:4092 NOTICE: StorageServer Module loaded RUN
20:11:15 T:4092 NOTICE: StorageClient-0.9.2 Starting server
20:11:15 T:4092 NOTICE: StorageServer-0.9.2 Storage Server starting C:\Users\Wearver\AppData\Roaming\XBMC\userdata\Database\commoncache.db
20:11:17 T:5768 NOTICE: -->Python Interpreter Initialized<--
20:11:18 T:6188 ERROR: Error evaluating boolean expression ![substring(ListItem.filename,bluray) | substring(ListItem.filename,blu-ray) | substring(ListItem.filename,bdrip) | substring(ListItem.filename,hddvd) | substring(ListItem.filename,hdtv) | substring(ListItem.filename,web) | substring(ListItem.filename,dvd) | substring(ListItem.filename,3dbd) | substring(ListItem.filename,.iso,Right) | substring(ListItem.filename,.ifo,Right) |
20:11:18 T:6188 ERROR: Error parsing label - missing ']' in "$INFO[ListItem.VideoCodec,flags/videocodec/,.png | substring(Container(8000).ListItem.filename,bluray) | substring(Container(8000).ListItem.filename,blu-ray) | substring(Container(8000).ListItem.filename,bdrip) | substring(Container(8000).ListItem.filename,hddvd) | substring(Container(8000).ListItem.filename,hdtv) | substring(Container(8000).ListItem.filename,web) | substring(Container(8000).ListItem.filename,dvd) | substring(Container(8000).ListItem.filename,3dbd) | substring(Container(8000).ListItem.filename,.iso,Right) | substring(Container(8000).ListItem.filename,.ifo,Right)]">$INFO[Container(8000).ListItem.VideoCodec,flags/videocodec/,.png"
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,chi)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,cho)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,ces)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,dan)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,dut)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,nld)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,eng)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,fre)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,ger)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,deu)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,gre)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,heb)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,hun)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,ita)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,jpn)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,kor)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,mdr)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,per)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,pol)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,por)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,ron)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,rus)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,spa)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,srp)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,swe)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,tha)
20:11:18 T:6188 ERROR: unmatched parentheses in substring(Container(8000).ListItem.Property(AudioLanguage,zul)
Hi
Did you solve this problem, I am have similar issues
(2012-04-01, 15:26)RavenNL Wrote: [ -> ]http://forum.xbmc.org/showthread.php?tid=127193
