Full Version: XBMC wont open after update please Help
Hello out there,
I was using the second beta for some time and
wanted to update to the final version now.
After killing the xbmchelper everything worked
fine, until the start of xbmc.
It crashes even before the logo comes up:
http://pastebin.com/WStbyvgA
Please help me, as the weekend is coming quiet close!
Thanks in advance
Alex
Try moving the xbmc folder from library --> application support
to the desktop temporarily then try starting the app again.
What happens?
Thanks for you help!
Did so and found out, that it was a problem with the database !?!
Eport -> import and all works.
