Eden 11.0
In the weather gui some translation error available to german language.
Overcast -> Bewölkt
Chance of Regen -> Teilweise Regen
Is this a translation error in a string.xml file or is this delivered by the api?
Zippolighter
It is a known problem. I already reported it before Eden, but it was too late to change the weather token strings.
See discussion here:
https://github.com/xbmc/xbmc/pull/575
The problem will probably be solved by itself if Ronie can get use of the Localization feature of the new Wunderground API.
Hi alanwww1
thanks for the info
Zippolighter
