Full Version: Eden - Update Library command
Hello everyone.
I'm using a Logitech Harmony remote with my xbmc-setup, and it's working fantastic.
I have a custom key for updating the library (think it executes xbmc.libraryUpdate or something. I can get the correct command if it matters)
Just upgraded to Eden, and now this button is not working. (my reboot-custom-butting is still working)
Can anyone help me with the new command?
Best regards
Sindre
Nobody who can help me with the command?
What exactly is the action mapped to?
I have a harmony as well and my update library button still works fine with eden...
I figured out what went wrong:
My xbmc don't seem to "care about" the files located in /home/username/.xbmc/userdata, so my keymaps/remote.xml don't do shit.
And therefore i have to use /usr/share/xbmc/system/keymaps/remote.xml, and of course this gets over-written when i update xbmc.
Did some testing just now, and whatever i do to my /home/username/.xbmc/userdata/keymaps/remote.xml, xbmc don't care. Sad
have you looked at the debug log? Or validated the XML? Because I bet something in there is wrong.
Everything is working now, can I copy /usr/share/xbmc/system/keymaps/remote.xml to /home/username/.xbmc/userdata/keymaps/remote.xml and everything should be OK?
And everything should work after next update!?
It should.
