Full Version: "Set Content" does not save settings
Just upgraded to Eden using the live disc and now I cannot set the content of any local folders or network drives connected to the system.
Everything seems to go fine as far as selecting scrapers.
Clicking on OK brings up a box asking if I want to update the library.
Updating the library brings up a status bar for a moment, but it doesn't do any searching. (selecting no causes nothing to happen)
Now if I go back and look at the content settings for the folder/source that I just set, it is back to a blank default as if I never touched it.
I have tried with the built in scrapers for movie, TV, and music videos plus one third party scraper. None of them are saved after selecting OK.
need debug log (wiki)
(2012-03-30, 22:01)Ned Scott Wrote: [ -> ]need debug log (wiki)
Here's an exciting debug log full of error.
http://pastebin.com/p5TD85cF
Looks like a missing SQL database or service may be the issue, but I am unsure how to fix that.
(2012-03-31, 01:33)jmarshall Wrote: [ -> ]Follow the wiki: http://wiki.xbmc.org/index.php?title=HOW..._libraries
Do these instructions still apply even though I only have one system running XBMC?
Does the new live disc not set up a fully functioning copy of XBMC or is this some sort of install error?
I didn't bother actually reading your log, and just assumed :p
You need to delete your database files in userdata - they're corrupt.
That did the trick.
Thank you very much.
