Full Version: RTSP streams in xbmc
Whenever I play rtsp streams in xbmc, the quality becomes very choppy & blocky using the in built player, unwatchable as it pixelates a lot
The rtsp stream works perfectly if I play it in VLC for instance, this only happens in XBMC.
Any ideas how to fix this? Is it a codec issue or something?
I am having the same problem, were you able to find a solution? I am actually trying to watch rtsp stream on Apple TV2
