Hello I love transparency and I wonder if it is possible to add the SCRIPT that allows for the playlist with widjet thank you
i'm afraid i'm not sure what you're looking for...
playlist widget?
(2012-04-01, 15:53)ronie Wrote: [ -> ]i'm afraid i'm not sure what you're looking for...
playlist widget?
Yes a member of passion-xbmc at creating a scrypt to display the playlist in a widget.
The scrypt is present in aeon nox and glass.
Randomlastitem
ah, ok :-)
i will look into it one it's added to our addon repo.
