2012-04-02, 09:12
I'm new to forums, apologies if this post is in the wrong place!
As the title suggests, I have a scraping issue whereby TV shows are not being scrapped at all. I have re-installed XBMC maybe 8/9 times over the weekend, yet I get the same result each time: I add the source through videos--> add source --> TV Shows, set the content to TV shows, and the scraper does not scrape anything. I have confirmed the path is correct as when I click on Videos --> TV shows, it shows me all the folders they should be scraping.
I think I have a scarping problem in general, as I added a few new movies to the NAS last night, but they were not scraped either. However being a complete noob to XBMC, its prob best to take one issue at a time!
My debug log: http://pastebin.com/dU2cBaDf
In an attempt to try and learn to fix the problem myself, I think the issue can be resolved through re-setting the database, but I would appreciate it if someone could explain why this would work: rm -f /private/var/mobile/Library/Preferences/XBMC/userdata/Database/*db
I think this is the solution as under Settings --> Skin --> Home Menu, I can hide Movies from showing in the menu, but I the option to hide TV Shows (despite setting the source up, labelling as TV Shows and setting content as TV Shows) is greyed out.
Thank you for you help!
Gary
Gary
