Full Version: [SOLVED] Automatically play next episode
I'm new to XBMC and I love it. I can't believe it's free :-)
However, I'm struggling with something. I'm sure the solution is straight-forward, but I cannot find anything in the forum.
I would like to know if it is possible for XBMC to start playing the next episode (of a TV show) automatically.
Say e.g. I have a "Friends -> Season 1" folder and inside there are EPISODE 1, EPISODE 2, EPISODE 3 etc. After EPISODE 1 I would like XBMC to start playing EPISODE 2 automatically (instead of returning to the list of Episodes).
Is this at all possible?
Many thanks
Hi there,
If you go to the context menu (c on your keyboard) you will see an option that says "play from here".
That will play one episode after another.
Aah, that is valuable information.
Thank you
