If there are more than one language for a movie, how does one select between the languages?
How can I tell if there are more than one language track for a movie?
thanks
When playing the movie if you bring up the OSD and go to the "Audio and Subtitle Settings" then there is an option to select the audio stream, and it will have 1 / 2 etc dependant on how many there are. It should just be from changing that.
Got it! Thanks - very simple once you know how.
It's an audio stream 7.x vs 5.x, etc. This movie had three streams and I just cycled through them until I heard English.
Thanks again.
