I have modified some files in my HTPC to use (like on 9 and 10 versions of XBMC..) "OLD" XBMX DVD remote control on EDEN version..
http://wiki.xbmc.org/index.php?title=HOW...te_for_USB
But the romote don't work.. (in older versions of XBMC it work!!)
Any ideas?
Bye!
It's working on my config after switching from Dharma to Eden on a Ubuntu 10.4. I had nothing to change on this point.
But if you use a more recent version of Ubuntu, the way to manage the USB dongle must be changed. That's why I'm continue to use the 10.4 LTS.
Regards
I hope the wiki page will be updated..
Bye!
(2012-04-17, 15:33)vercingetorige Wrote: [ -> ] (2012-04-06, 17:11)vercingetorige Wrote: [ -> ] (2012-04-06, 14:15)divingmule Wrote: [ -> ]Do this -> http://ubuntuforums.org/showpost.php?p=1...stcount=19
I try it asap!!
Thanx!
I have no time to try... :-(
Someone try this?
Bye!
I done this for my step dad's HTPC I built for him using beta 3 of Eden. It works. One thing I don't like is the repeat function on it is a bit touchy.
The remote control is the Xbox DVD dongle
Greetings, I have several days trying to install this remote in XBMCbuntu, but I can not install it gives me error when installing the modules ( lirc-modules-source ).
This is the error that tells me:
sudo apt-get instal lirc-modules-source
I got the following response:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package lirc-modules-source is not available, but is referred to by another pack
age.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
lirc
E: Package 'lirc-modules-source' has no installation candidate
I currently have lirc installed and I cannot proceed without lirc-modules-source.
I would also like to assign to buttons on the remote control, 3 to increase the volume, 6 to lower the volume, mute 9 for, 1, 4 to zoom, 2 to activate the subtitles and 5 to change the language audio.
Try this but fails: http://ubuntuforums.org/showpost.php?p=1...stcount=19
prueba@prueba-VirtualBox:~$
sudo apt-get install lirc
[sudo] password for prueba:
lirc is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded
sudo nano /etc/modprobe.d/blacklist.conf
sudo update-initramfs -u
update-initramfs: Generating /boot/initrd.img-3.0.0-16-generic
sudo apt-get build-dep lirc
E: Unable to find a source package for lirc
I don't now if is important.. Have you changed permission on edited files?
I do.. (downloaded to the PC, edited whit "unix like" editor, uploaded end then chmod..)
Bye!
