Full Version: crash on smb browse
So everytime i try to browse to my smb share that was working up until recently i get an xbmc crash
here are the logs
http://pastebin.com/0ttcuD5s - old
http://pastebin.com/JSKxjWUx
Any help would be great
crashlog and syslog needed (first link in my signature).
Crash reporter - http://pastebin.com/6phQrcGd
sYSLOG - http://pastebin.com/7cUt0ryP
the syslog is only part as its a 24mb file and pastebin cant handle it at present..
wrong crashreporter file. look like something "AppleTV-latest" or so...
http://pastebin.com/Nt8nrsZT is the latest one that is in that format.. but its from last september it seems by the date..
sorry for all the confusion
yeah thats old ... reset your syslog
cat > /var/logs/syslog
after this command press ctrl + d
this will clear the syslog ... the make that crash happen again and post it to pastebin
i've tried this twice and still no new syslog and just all the same ones in there?
what should i say about thatHuh
i successfully executed that command
it took a while then i hit ctrl +d
then i replicated crash and went to the crashlog folder and it looks exactly the same as before with the newest date being last september
get me that syslog now which should fit on pastebin because the command i told you should have cleared that log...
here it is here - same as before - http://pastebin.com/HR16SV3a
only can paste in part so pasted in the latest
i don't mind reinstalling xbmc if you can tell me the best way to do that.
just so you know. i can ssh into the atv via putty but it doesnt seem to respond to any of the commands i type in anymore
as of that syslog you didn't crash xbmc ... man its really starting to bore me a bit ... never had to ask so much for getting the right logs Sad. Maybe someone else could take over here and get me the right syslog, with the right crashlog and the right xbmc.log.
Uninstall Firecore Media Player if you have it.
Uninstalling Media Player worked perfect! There's not really a point having it anyway...
