Full Version: Starting HTPC with Remote (Asrock h67m-ge/ht)
Hello,
i use for my HTPC a Asrock h67m-ge/ht Mainboard, which comes up with an MCE Remote control.
One of the main reasons I bought this board is the feature that the pc can be started with the remote control.
It is mentioned here:
http://www.asrock.com/mb/overview.asp?Model=H67M-GE/HT (scroll down a bit)
There is says:
Quote:MCE Remote Controller
The Microsoft® MCE (Media Center Edition) function features an entire entertainment center which allows you to enjoy a more convenient way of viewing photos, playing DVDs, watching TV, listening to music, and so on. The MCE Remote Controller not only lets you enjoy the digital programs thoroughly but also allows you to power on/off the system more easily. The most important is that it is the world’s first MCE remote controller which is able to power on your PC from ACPI S5 mode.
So ACPI S5 mode is complete shutdown, no energy save etc. mode
My problem is that my pc will not start by remote control. The control works great, i can even shutdown the system, but not start it.
Does anyone else use this board/remote and can help me?
i dont own it,
but you need to install the drivers for it,,,
ftp://174.142.97.10/Drivers/nettop/cir/N...9_CIR).zip
also, triple check in your BIOS to see
if CIR CONTROLLER is enabled....
Drivers are installed and Bios-setting is enabled, otherwise the remote won't work at all.......
But it works, just Booting is not working....
booting then should work...
contact/open an ASROCK support ticket
http://www.asrock.com/support/tsd.asp
also make sure u have latest BIOS version
and maybe this can help
http://forums.tweaktown.com/asrock/46934...tx-ht.html
and you may retry these steps carefully
http://www.asrock.com/support/faq.asp?id=275
so unplug everything and retry..
it really can be as stupid as this....
sometimes, u need to install stuff following a precise sequence...
(2012-04-06, 15:21)eskro Wrote: [ -> ]and you may retry these steps carefully
done that many times before, not working.
If i shut down to energy saving mode or standby, it will start correctly.
And, if i shut down, and start up in the first seconds after shut down, it will start too.
It seems like for a few seconds the CIR has some power left to receive signals from the remote...
well what can i say then,,,
all is left for you is to ask ASROCK...
@torro-
Unfortunately, I don't think that your mobo support CIR on/off option. If it is, it usually included these updates in BIOS-
1. Update CPU code.
2. Improve USB mouse function.
Having a remote controller doesn't mean that it can turn on a PC. The remote controller is for MCE purposes only. My wife all-in-one PC included MCE remote controller, and it cannot turn on the PC either. It can control just about everything related to MCE though.......
@bluray:
Read the first post, the qoute from ASRock product specification says clearly that it should start the system with the remote.....
(2012-04-06, 19:52)Torro14 Wrote: [ -> ]@bluray:
I understand that the remote can be used to turn on/off the PC, but it have to have the proper software (bios) and hardware (CIR header) to support it. I knew about AsRock Smart Remote since I bought my first AsRock MOBO a little over a year ago.You can contact AsRock for assistant on it then.....
if this is your motherbaord --> http://www.newegg.com/Product/Product.as...6813157235
it should work,
(2012-04-07, 00:51)eskro Wrote: [ -> ]if this is your motherbaord --> http://www.newegg.com/Product/Product.as...6813157235
it should work,
That is the same MOBO as his OP.....
exactly why i said it in post #11
Is your jumper setting correct? Meaning did you take the Front USB Jumper and set half the jumper on the CIR Circuit and the other on the USB Circuit? That may be the problem.
And if it is correct, then move the IR Receiver to the other Front USB Port.
