As far as spec, it come down to Lenovo Q180 vs. Acer Revo RL70....to me, Q180 looks nicer.....!
Thanks for replying
So q180 is probably better spec wise?
And ati vs nvidia makes no difference in choice? I would like to try to boot straight into xbmcbuntu for the wife's sake
(2012-04-07, 18:07)roy8846 Wrote: [ -> ]Thanks for replying
For xbmcbuntu, you might have easier time with Nvidia graphic card. What happen with Windows? XBMC+Windows 7 is as good as it get, and you can customize XBMC startup with this guide-
Customizing Windows for XBMC
Brill thanks for that.
So the atom is better than e450
Or is it the gfx that count more between them?
(2012-04-07, 18:58)roy8846 Wrote: [ -> ]Brill thanks for that.
You make the call: here are the spec Intel Atom 2700 (2.13GHz dual-core+AMD HD6450A) vs. AMD E450 (1.65GHz dual-core+HD6320).....
That's the point I have no idea, guess I will go with consensus in this thread
Thanks for the help though and at least responding to a noob
(2012-04-07, 20:47)roy8846 Wrote: [ -> ]That's the point I have no idea, guess I will go with consensus in this thread
For the same price, go for the system with better spec.....in this case, Lenovo Q180 got my vote......
To answer my own question ,
I went for a Lenovo Q180 and a Xenta Wireless Keyboard/Trackpad and its real nice kit for the money...
Havent done any HD tests yet but flash works real nice and XBMC works a treat
(with Confluence skin at least)
(2012-04-11, 18:54)roy8846 Wrote: [ -> ]To answer my own question ,
Havent done any HD tests yet but flash works real nice and XBMC works a treat (with Confluence skin at least)
I'm glad that everything work out great for you. Yes, throw some HD movies in it.......
That is a very nice keyboard/mouse combo. If you want a smaller keyboard/mouse/remote controller combo, this "
Lenovo N5902" is a sleek device....
If you are interesting in bitstreaming HD audio with it, you can check out my signature below....
I am just about to buy one of these but wanted to check it works ok with OpenElec Intel or generic builds? I am currently running a Revo 3700 with a OpenElec Ion build.
Thanks in Advance
I'm thinking of buying the lenovo aswell did you tried the HD 3D..?
How long does it takes to boot to XBMC?
The Q180 is on sale right now for $330. I'm debating on this vs. a brand new Revo RL70 on Craigslist for $250.
It doesn't need to be fast, or do anything online. It won't even be connected to a network. Strictly playback of 720p .mkv Disney cartoon BluRays via XBMC under Windows 7, connected via HDMI to a 50" LED TV.
What's the consensus?
