2012-04-08, 08:29
I was running XBMC Dharma on my Shuttle XS35GT. I then update to XBMC Eden. Everything worked. Then after a few days when the movie I was looking at was ended my MCE Remote didn’t work.
First I thought the battery was bad. I change them. Still doesn’t work. When I press on a button I can see on the IR receiver that receives my desperate presses. Changed USB-port. Still nothing. If I connect a USB thumdrive that will pop-up so nothing wrong with the USB-ports. I connected the IR-Receiver to my Windows computer and installed XBMC there. Here the remote works. So no hardware error with the remote.
After thinking a few days I just reinstalled my Shuttle XS35GT with the latest XBMCbuntu. Ahhh but still the remote doesn’t work.
I have followed this guide to make the sound work over HDMI on my Shuttle
http://breden.org.uk/2011/01/15/shuttle-...ve-dharma/
This is my Remote control (I think, look just like it)
http://www.mythtv.org/wiki/File:MCE-Remote-2-v1069.jpg
Unfortunately I’m not a Linux guy but I’m trying.. this is what I have done to check things out..
If I run “lsusb” I get…
cat /proc/bus/input/devices gives me…
lsmod | grep lirc gives me...
My /etc/lirc/hardware.conf looks like this…
My /etc/lirc/lircd.conf looks like this...
Don’t know if it’s needed to post the /usr/share/lirc/remotes/mceusb/lircd.conf.mceusb because it’s fairly long text.
But what should I do next. Right now I’m using my android phone with the XBMC remote but it’s not the same thing. Need this baby up and running.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 0609:0334 SMK Manufacturing, Inc. eHome Infrared Receiver
I: Bus=0003 Vendor=0609 Product=0334 Version=0100
N: Name="Media Center Ed. eHome Infrared Remote Transceiver (0609:0334)"
P: Phys=usb-0000:00:1d.3-2
S: Sysfs=/devices/pci0000:00/0000:00:1d.3/usb5/5-2/5-2:1.0/rc/rc0/input4
U: Uniq=
H: Handlers=kbd event4
B: PROP=0
B: EV=100013
B: KEY=fff 0 0 200 108fc32e 2376051 0 0 0 7 158000 4192 1 9e9680 0 0 10000000
B: MSC=10
ir_lirc_codec 12770 3
lirc_dev 18700 1 ir_lirc_codec
rc_core 25797 9 ir_lirc_codec,ir_sony_decoder,ir_jvc_decoder,ir_rc6_decoder,ir_rc5_decoder,rc_rc6_mce,ir_nec_decoder,mceusb
#Chosen Remote Control
REMOTE="Windows Media Center Remotes (new version Philips et al.)"
REMOTE_MODULES="lirc_dev lirc_mceusb2"
REMOTE_DRIVER=""
REMOTE_DEVICE="/dev/lirc0"
REMOTE_LIRCD_CONF="mceusb/lircd.conf.mceusb"
REMOTE_LIRCD_ARGS=""
#Chosen IR Transmitter
TRANSMITTER="None"
TRANSMITTER_MODULES=""
TRANSMITTER_DRIVER=""
TRANSMITTER_DEVICE=""
TRANSMITTER_LIRCD_CONF=""
TRANSMITTER_LIRCD_ARGS=""
#Enable lircd
START_LIRCD="true"
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD="false"
#Try to load appropriate kernel modules
LOAD_MODULES="true"
# Default configuration files for your hardware if any
LIRCMD_CONF=""
#This configuration has been automatically generated via
#the Ubuntu LIRC package maintainer scripts.
#It includes the default configuration for the remote and/or
#transmitter that you have selected during package installation.
##Feel free to add any custom remotes to the configuration
#via additional include directives or below the existing
#Ubuntu include directives from your selected remote and/or
#transmitter.
#Configuration for the Windows Media Center Remotes (new version Philips et al.) remote:
include "/usr/share/lirc/remotes/mceusb/lircd.conf.mceusb"
