The current version of edition xbmcfreaks (xbmcbuntu) is proftpd, sabnzbd and sick beard supported. But how can I enable these addons? Do I have to install them via terminal session?
(2012-04-08, 08:52)motocat Wrote: [ -> ]Hi,
sabnzbd:
FIrst, edit your
/etc/default/sabnzbdplus file as root (sudo) and enter the information
Quote:USER=
HOST=
PORT=
Then save the file and start sabnzbd with
sudo service sabnzbdplus start and then point your web-browser to it:
http://HOST:PORT and continue with the setup.
sickbeard:
I didn't use the sickbeard install that it came with, I just re-downloaded it myself and put it in ~/.sickbeard . If you want to use the built-in, the files are located in
/usr/share/sickbeard including the ubuntu init file.
proftpd:
I didn't have to do anything for this, its already working out-of-the-box[/b][/quote]
I found an issue when configuring all the addons on start-up. Will release another version later this week.
