Full Version: Compiling XBMC EDEN in Ubuntu 10.04.4 LTS i386
Hello i try comiling xbmc eden 11.0 in ubuntu 10.04.4 LTS my hardware is gigabyte MA785GT-UD3H with HD4200 embed
well i download git version, becouse i need VAAPI acceleration
when configure xbmc i have an error
Quote: ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for g++... g++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of g++... none
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... none
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking whether we are using the GNU C++ compiler... (cached) yes
checking whether g++ accepts -g... (cached) yes
checking dependency style of g++... (cached) none
checking how to run the C++ preprocessor... g++ -E
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking for gawk... (cached) gawk
checking whether make sets $(MAKE)... (cached) yes
checking for working alloca.h... yes
checking for alloca... yes
checking for uid_t in sys/types.h... yes
checking for unistd.h... (cached) yes
checking for working chown... yes
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking whether closedir returns void... no
checking for error_at_line... yes
checking for _LARGEFILE_SOURCE value needed for large files... no
checking whether gcc needs -traditional... no
checking whether lstat correctly handles trailing slash... yes
checking whether lstat accepts an empty string... no
checking whether lstat correctly handles trailing slash... (cached) yes
checking for working memcmp... yes
checking whether time.h and sys/time.h may both be included... yes
checking for sys/time.h... yes
checking for stdlib.h... (cached) yes
checking for sys/param.h... yes
checking for utime.h... yes
checking for alarm... yes
checking for working mktime... yes
checking for getpagesize... yes
checking for working mmap... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking types of arguments for select... int,fd_set *,struct timeval *
checking return type of signal handlers... void
checking whether stat accepts an empty string... no
checking for working strcoll... yes
checking for strftime... yes
checking for working strtod... yes
checking whether utime accepts a null argument... yes
checking for vprintf... yes
checking for _doprnt... no
checking for atexit... yes
checking for dup2... yes
checking for fdatasync... yes
checking for floor... no
checking for fs_stat_dev... no
checking for ftime... yes
checking for ftruncate... yes
checking for getcwd... yes
checking for gethostbyaddr... yes
checking for gethostbyname... yes
checking for gethostname... yes
checking for getpagesize... (cached) yes
checking for getpass... yes
checking for gettimeofday... yes
checking for inet_ntoa... yes
checking for lchown... yes
checking for localeconv... yes
checking for memchr... yes
checking for memmove... yes
checking for memset... yes
checking for mkdir... yes
checking for modf... yes
checking for munmap... yes
checking for pow... no
checking for rmdir... yes
checking for select... yes
checking for setenv... yes
checking for setlocale... yes
checking for socket... yes
checking for sqrt... no
checking for strcasecmp... yes
checking for strchr... yes
checking for strcspn... yes
checking for strdup... yes
checking for strerror... yes
checking for strncasecmp... yes
checking for strpbrk... yes
checking for strrchr... yes
checking for strspn... yes
checking for strstr... yes
checking for strtol... yes
checking for strtoul... yes
checking for sysinfo... yes
checking for tzset... yes
checking for utime... yes
checking size of int... 4
checking size of size_t... 4
checking sys/inotify.h usability... yes
checking sys/inotify.h presence... yes
checking for sys/inotify.h... yes
checking boost/shared_ptr.hpp usability... yes
checking boost/shared_ptr.hpp presence... yes
checking for boost/shared_ptr.hpp... yes
checking for main in -lGL... no
configure: error: Could not find a required library. Please see the README for your platform.
Thank you.
I had the same issue. It's because there is no OpenGL installed.
I just installed the latest NVidia video drivers, and that fixed it for me.
yes but i don't have a nvidia card i have ati radeon hd4200 emebed motherboard
I install ad driver catalyst 12.3
Quote: ls -la /usr/lib/libGL.so*
lrwxrwxrwx 1 root root 13 2012-04-09 11:00 /usr/lib/libGL.so -> mesa/libGL.so
lrwxrwxrwx 1 root root 21 2012-04-09 10:29 /usr/lib/libGL.so.1 -> /usr/lib/libGL.so.1.2
lrwxrwxrwx 1 root root 33 2012-04-09 10:29 /usr/lib/libGL.so.1.2 -> /usr/lib/fglrx/fglrx-libGL.so.1.2
connect my Htpc with HDMI
Quote:vainfo
libva: libva version 0.32.0-sds2
Xlib: extension "XFree86-DRI" missing on display ":0.0".
libva: va_getDriverName() returns 0
libva: Trying to open /usr/lib/va/drivers/fglrx_drv_video.so
libva: va_openDriver() returns 0
vainfo: VA API version: 0.32
vainfo: Driver version: Splitted-Desktop Systems XvBA backend for VA-API - 0.8.0
vainfo: Supported profile and entrypoints
VAProfileH264High : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
well i uninstall catalyst 12.3 and install catalyst 12.2
Quote:ls -la /usr/lib/libGL.so*
lrwxrwxrwx 1 root root 19 2012-04-09 15:39 /usr/lib/libGL.so -> /usr/lib/libGL.so.1
lrwxrwxrwx 1 root root 21 2012-04-09 15:39 /usr/lib/libGL.so.1 -> /usr/lib/libGL.so.1.2
lrwxrwxrwx 1 root root 33 2012-04-09 15:39 /usr/lib/libGL.so.1.2 -> /usr/lib/fglrx/fglrx-libGL.so.1.2
i can configure without error but i don't have VAAPI
Quote:------------------------
XBMC Configuration:
Debugging: Yes
Profiling: No
Optimization: Yes
Crosscomp.: No
target ARCH: no
target CPU: no
OpenGL: Yes
ALSA: Yes
DBUS: Yes
VDPAU: No
VAAPI: No
CrystalHD: No
VDADecoder: No
VTBDecoder: No
OpenMax: No
Joystick: Yes
XRandR: Yes
GOOM: No
RSXS: Yes
ProjectM: Yes
Skin Touched: No
X11: Yes
Bluray: No
TexturePacker:Yes
MID Support: No
ccache: No
PulseAudio: Yes
HAL Support: Yes
DVDCSS: Yes
Avahi: Yes
Non-free: Yes
ASAP Codec: No
Webserver: Yes
libRTMP support: No
libsmbclient support: Yes
libnfs client support:No
libafpclient support: No
AirPlay support: Yes
AirTunes support: No
Optical drive: Yes
libudev support: Yes
libusb support: No
libcec support: No
External FFmpeg: No
prefix: /usr/local
Aren't there any PPAs out there anymore for 10.04 LTS? That might save you the trouble of compiling.
Also, if you're running ATi, try the XvBA branch, it's way more stable than the VA-API implementation.
binaries for the xvba branch are in my ppa(click my sig), also for lucid.
(2012-04-09, 17:27)wsnipex Wrote: [ -> ]binaries for the xvba branch are in my ppa(click my sig), also for lucid.
Thank you, but i don't have install xbmc becouse
Quote: xbmc: Depende: fglrx (>= 2:8.911) pero no va a instalarse o
fglrx-updates (>= 2:8.911) pero no es instalable
I have install ati catalyst 12.2 386
you need to install catalyst as deb package ( --buildandinstallpkg to the installer)
ok, thx. i try with this.
