gfdsa - I just pushed a possible fix in for your issue, can you please re-test and post your debug log.
ScotchTape - That would be awesome
(2012-05-09, 09:57)gfdsa Wrote: [ -> ]@gnif, just a side not and a suggestion maybe. Shouldn't HDMI outputs be treated differently from iec958? Afaik they are different as capabilities and the string "HDMI" seems to be a reliable way to detect them.
My -aplay lists all outputs as "HDMI", so that's not reliable.
robo989, what does "aplay -L show"? not "aplay -l"
gnif, seems it does find HDMI now. I am away from the box now, will test the sound and picture tonight when I am back home.
11:47:11 T:3008022912 INFO: Enumerated ALSA devices:
11:47:11 T:3008022912 INFO: Device 1
11:47:11 T:3008022912 INFO: m_deviceName : hw:CARD=Intel,DEV=0
11:47:11 T:3008022912 INFO: m_displayName : HDA Intel
11:47:11 T:3008022912 INFO: m_displayNameExtra: STAC92xx Analog
11:47:11 T:3008022912 INFO: m_deviceType : AE_DEVTYPE_PCM
11:47:11 T:3008022912 INFO: m_channels : FL,FR
11:47:11 T:3008022912 INFO: m_sampleRates : 44100,48000,88200,96000,176400
11:47:11 T:3008022912 INFO: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE
11:47:11 T:3008022912 INFO: Device 2
11:47:11 T:3008022912 INFO: m_deviceName : hdmi:CARD=Intel,DEV=0
11:47:11 T:3008022912 INFO: m_displayNameExtra: STAC92xx Digital
11:47:11 T:3008022912 INFO: m_deviceType : AE_DEVTYPE_HDMI
11:47:11 T:3008022912 NOTICE: load settings...
(2012-05-09, 10:10)gnif Wrote: [ -> ]@gfdsa - We detect HDMI vs IEC958, the problem is your device doesnt report HDMI in its hardware name at all
Yes, sorry, did mix the device and pcm names again.
Firstly a great product, however I have a challenge, it is not picking up the ALSA device for my Nvidia. I have an old AMD system I am using with an imbedded Soundblaster card which I do not want to use. I have a NVIDIA GTX460 Card. In normal XBMC (running in parallel) it can see the NVIDIA Card so I know the driver is working (Although the sound is rubbish hence why I want to use this).
I am using Drivers 290.10 (I was using 295 but uninstalled after reading first post), system is ubuntu 11.10
Output from aplay -l
card 0: CA0106 [CA0106], device 0: ca0106 [CA0106]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: CA0106 [CA0106], device 1: ca0106 [CA0106]
Subdevices: 1/1
card 0: CA0106 [CA0106], device 2: ca0106 [CA0106]
Subdevices: 1/1
card 0: CA0106 [CA0106], device 3: ca0106 [CA0106]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 0 [HDMI 0]
Subdevices: 1/1
output from xbmc.log
15:24:38 T:3048978192 INFO: CAESinkALSA::EnumerateDevicesEx - Unable to open hw:1 for capability detection
15:24:38 T:3048978192 INFO: Previous line repeats 3 times.
15:24:38 T:3048978192 ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
15:24:38 T:3048978192 INFO: Enumerated ALSA devices:
15:24:38 T:3048978192 INFO: Device 1
15:24:38 T:3048978192 INFO: m_deviceName : hw:CARD=CA0106,DEV=0
15:24:38 T:3048978192 INFO: m_displayName : CA0106
15:24:38 T:3048978192 INFO: m_displayNameExtra: CA0106
15:24:38 T:3048978192 INFO: m_deviceType : AE_DEVTYPE_PCM
15:24:38 T:3048978192 INFO: m_channels : FL,FR
15:24:38 T:3048978192 INFO: m_sampleRates : 48000,96000,192000
15:24:38 T:3048978192 INFO: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE
15:24:38 T:3048978192 INFO: Device 2
15:24:38 T:3048978192 INFO: m_deviceName : hw:CARD=CA0106,DEV=1
15:24:38 T:3048978192 INFO: Device 3
15:24:38 T:3048978192 INFO: m_deviceName : hw:CARD=CA0106,DEV=2
15:24:38 T:3048978192 INFO: Device 4
15:24:38 T:3048978192 INFO: m_deviceName : hw:CARD=CA0106,DEV=3
When I go into XBMC i just see the CA0106 in the Audio Options.
Thanks hope I can assist in the project.
Dave
Apologies, reading back a few here is the aplay -L log which I think you also need.
null
Discard all samples (playback) or generate zero samples (capture)
hdmi-remap
remap-surround71
dmixer
default
front:CARD=CA0106,DEV=0
CA0106, CA0106
Front speakers
rear:CARD=CA0106,DEV=0
CA0106, CA0106
Rear speakers
center_lfe:CARD=CA0106,DEV=0
CA0106, CA0106
Center and Subwoofer speakers
side:CARD=CA0106,DEV=0
CA0106, CA0106
Side speakers
surround40:CARD=CA0106,DEV=0
CA0106, CA0106
4.0 Surround output to Front and Rear speakers
surround41:CARD=CA0106,DEV=0
CA0106, CA0106
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=CA0106,DEV=0
CA0106, CA0106
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=CA0106,DEV=0
CA0106, CA0106
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=CA0106,DEV=0
CA0106, CA0106
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=CA0106,DEV=0
CA0106, CA0106
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=CA0106,DEV=0
CA0106, CA0106
Direct sample mixing device
dmix:CARD=CA0106,DEV=1
CA0106, CA0106
dmix:CARD=CA0106,DEV=2
CA0106, CA0106
dmix:CARD=CA0106,DEV=3
CA0106, CA0106
dsnoop:CARD=CA0106,DEV=0
CA0106, CA0106
Direct sample snooping device
dsnoop:CARD=CA0106,DEV=1
CA0106, CA0106
dsnoop:CARD=CA0106,DEV=2
CA0106, CA0106
dsnoop:CARD=CA0106,DEV=3
CA0106, CA0106
CA0106, CA0106
Direct hardware device without any conversions
CA0106, CA0106
CA0106, CA0106
CA0106, CA0106
plughw:CARD=CA0106,DEV=0
CA0106, CA0106
Hardware device with all software conversions
plughw:CARD=CA0106,DEV=1
CA0106, CA0106
plughw:CARD=CA0106,DEV=2
CA0106, CA0106
plughw:CARD=CA0106,DEV=3
CA0106, CA0106
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
dmix:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
dmix:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
dmix:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
dmix:CARD=NVidia,DEV=9
HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=9
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=9
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=9
HDA NVidia, HDMI 0
Hi
Fixed the detection of the NVIDIA device was caused by the remapping in the following wiki entry which I used for my old XBMC install:
http://wiki.xbmc.org/index.php?title=HOW...controller
now detects pass through device but audio device is still CA0106 which is strange.
Apologies for earlier posts
(2012-05-09, 10:39)gnif Wrote: [ -> ]@gfdsa - I just pushed a possible fix in for your issue, can you please re-test and post your debug log.
@ScotchTape - That would be awesome
Found the card, Audigy2, model SB0360 (ZS Platinum), Chip CA0102-ICT.
aplay -L
null
pulse
PulseAudio Sound Server
default:CARD=Audigy2
SB Audigy 2 ZS [SB0360], ADC Capture/Standard PCM Playback
Default Audio Device
sysdefault:CARD=Audigy2
front:CARD=Audigy2,DEV=0
Front speakers
rear:CARD=Audigy2,DEV=0
Rear speakers
center_lfe:CARD=Audigy2,DEV=0
side:CARD=Audigy2,DEV=0
Side speakers
surround40:CARD=Audigy2,DEV=0
surround41:CARD=Audigy2,DEV=0
surround50:CARD=Audigy2,DEV=0
surround51:CARD=Audigy2,DEV=0
surround71:CARD=Audigy2,DEV=0
iec958:CARD=Audigy2,DEV=0
dmix:CARD=Audigy2,DEV=0
dmix:CARD=Audigy2,DEV=2
SB Audigy 2 ZS [SB0360], Multichannel Capture/PT Playback
dmix:CARD=Audigy2,DEV=3
SB Audigy 2 ZS [SB0360], Multichannel Playback
dmix:CARD=Audigy2,DEV=4
SB Audigy 2 ZS [SB0360], p16v
dsnoop:CARD=Audigy2,DEV=0
dsnoop:CARD=Audigy2,DEV=2
dsnoop:CARD=Audigy2,DEV=3
dsnoop:CARD=Audigy2,DEV=4
hw:CARD=Audigy2,DEV=0
hw:CARD=Audigy2,DEV=2
hw:CARD=Audigy2,DEV=3
hw:CARD=Audigy2,DEV=4
plughw:CARD=Audigy2,DEV=0
plughw:CARD=Audigy2,DEV=2
plughw:CARD=Audigy2,DEV=3
plughw:CARD=Audigy2,DEV=4
Who needs it?
Can we please post command outputs in code blocks (like ScotchTape did) and larger pastes (like logs) in some kind of external service (pastebin, gist, etc).
Thanks everyone.
(2012-05-09, 20:25)ScotchTape Wrote: [ -> ]Who needs it?
Like mine. I think it's a good analog card. Just for curious: AE is working with this card to you?
Don't know, I just throwed it into my NAS to check if it's working and for the alsa-output. To test it in my HTPC is more complicated, starting with cables...
ok thanks again for availability! I could cover shipment costs if needed.
gnif, works, properly enumerated and selected HDMI for both normal out and passthrough. GUI sounds properly work (with some delay after playing a movie). HDMI passthrough works with 5.1 AC3 and DTS. Don't have other content at the moment.
Got segfaults twice but caused by VDPAU, the second one locked the nvidia driver, had to reboot to have X back. I suppose it is not related to AE.
Will be pulling and trying further with different content.
Always here if other infos from me can be useful.
AE was just officially merged with master
