2012-04-09, 17:54
My mediacenter remote aren't working as it should, it's a remote i got from an old Packard Bell computer, it's a X10 RF MCE Remote Control, model OR32E.
It worked in Win7 MCE before i switched over to xbmcbuntu, although i had a hard time finding the correct drivers.
in xbmcbuntu it's hardly working. up, down, left, right are the only buttons doing what they should, 90% of the other buttons does nothing, when i was testing the buttons earlier to see which ones worked i noticed that i turn off the HTPC with the info button
I'ts been alot of years since i last used linux so i've forgotten the little i knew then.
I've been searching here for help and found stuff about keyboard.xml (which i don't have, only noBS.xml) and remote.xml which i don't have either, but can't find anything that helps, or more specific, can't find anything that i know how to do
Anyone have a newbie approach on what i could try?
