How would you name folders for movies that don't contain episodes? I get how you do multiple discs for a TV series, but say you have a set like Live 8 (
http://www.imdb.com/title/tt0462403/) that has 4 discs. I want to make sure tha teach one shows up as disc 1, 2, 3 & 4 and not just listed as "Live 8" four times so users know which one they are picking.
I don't think the way to name folders using episodes will work here...
That looks promising... thanks. Since i've ripped in VOB format (folders), looks like I want to play with movie stacking. I guess i need to create a folder for the movie and then a subfolder for each disk... then create the regular expression in the advancedsettings.xml.
Worth a shot... thanks!
Unfortunately, either VOB or ISO is the worst format possible for stacking. If you instead rip to pretty much anything else (mkv, avi whatever) then you'd have a seamless stacking experience.
Ofcourse, that may not be what you're after (the menus for example might be useful for you).
(2012-04-10, 08:17)jmarshall Wrote: [ -> ]Unfortunately, either VOB or ISO is the worst format possible for stacking. If you instead rip to pretty much anything else (mkv, avi whatever) then you'd have a seamless stacking experience.
Totaly in agreement...I personally think the best of both worlds is to:
- convert each file you want to keep as an mkv
- place all related files into a movie set for movies or in season 0 for tv shows so that it takes the place of a dvd/bd menu
The end result is one item in a list that when opened acts like a folder with only the media files you want instead of a bunch of behind the scenes and other extras taking up space on your hard drives.
