Hi Glave
I am certain that this issue has nothing to do with the library.
Just to clarify the situation.
I have 3 machines with XBMC, all using the same NAS for the library.
I inadvertantly updated one yesterday (apt-get upgrade) but didn't pay enough attention to notice that XBMC was being updated.
From that point on I was unable to scrape the TMDB (Unable to connect to remote server)
Initially I did not link the problem to the XBMC update and spent several hours searching google and trying different stuff.
The IMDB and TVDB scrapers both work fine.
Then I noticed on my second box that apt-get was reporting that XBMC was one of the updates in the pipeline.
Hmmm. I fired up XBMC and went to "Files" and "Movies" in the library, hit "Scan" and it worked fine. No problem at all.
I closed XBMC and did the apt-get upgrade.
When it was done, I opened up XBMC, the automatic scan started and failed with "Unable to connect to remote server"
The library is unchanged.
My third PC is still on the old version but I cannot access it right now, however I'm sure that it will still be working fine.
Here is the relevant part of the debug log;
VideoInfoScanner: No NFO file found. Using title search for '/store/archive/video/Movies/Pirates of the Caribbean 2: Dead Mans Chest (2005).avi'
12:02:42 T:140524858918656 DEBUG: FindMovie: Searching for 'Movie' using The MovieDB scraper (path: '/usr/share/xbmc/addons/metadata.themoviedb.org', content: 'movies', version: '3.0.9')
12:02:42 T:140524858918656 DEBUG: scraper: CreateSearchUrl returned <url>http://api.themoviedb.org/3/search/movie?api_key=57983e31fb435df4df77afb854740ea9&query=pirates%20of%20the%20caribbean%202%3a%20dead%20mans%20chest+2005&language=en</url>
12:02:42 T:140524858918656 DEBUG: FileCurl::Open(0x7fce7e4c3310)
http://api.themoviedb.org/3/search/movie...anguage=en
12:02:42 T:140524858918656 INFO: easy_aquire - Created session to
12:02:44 T:140524858918656 WARNING: FillBuffer: curl failed with code 22
12:02:44 T:140524858918656 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
12:02:44 T:140524858918656 ERROR: Run: Unable to parse web site
It just occured to me to check the URL that the VideoScanner is scraping from the above log.
This is the URL;
This is what is returned;
{"status_code":7,"status_message":"Invalid API key - You must be granted a valid key"}
