Running Eden on Arch Linux i686 using an old Athlon XP chip. Since updating from Dharma, idle CPU usage is 25-30 %. I tried using the
dirty regions modification and after reloading xbmc, I see no change in htop CPU usage. Suggestions are welcome.
$ cat advancedsettings.xml
<advancedsettings>
<loglevel>0</loglevel>
<gui>
<algorithmdirtyregions>1</algorithmdirtyregions>
<nofliptimeout>1000</nofliptimeout>
</gui>
</advancedsettings>
I should note that as a test case, I moved my "old" ~/.xbmc to ~/.xbmc-old and allowed xbmc to create one fresh. After disabling RSS feeds, I found exactly the same CPU usage while idle.
What CPU level wouldn't be excessive?
I'm assuming XBMC is working well for you otherwise
This is effecting my system too (C2D @ 3.33 GHz) so it's not just lower powered CPUs. With the GUI running idle is 6-8 % on BOTH cores. If I exit xbmc, the CPU usage drops down to 0-1 %. I can also confirm this problem on a low powered Atom-330 based system at a friend's house. There the idle is 23-25 % on one core while idle. I also applied the dirty regions settings but found no change.
(2012-04-09, 22:39)pseudo7 Wrote: [ -> ]What CPU level wouldn't be excessive?
If I downgrade the package to Dharma, I get 1-2 % while xbmc is idle so something is definitively different in Eden. It is working well for me otherwise. I opened a bug report:
http://trac.xbmc.org/ticket/12909 but am still willing to try suggestions and thank you!
Thanks for doing that bug report. I had the same problem on my atom, where it was averaging about 30% at idle. When playing videos, it went to 1 to 2%, if that.
I added the dirtyregion thing and it helped out, but I somehow feel iffy about it because when playback of videos, there's some pixelation. I don't know why this is happening, as the dirty region should only affect the gui. It could very well be another issue; it's too early to tell.
Having similar issue here too. I'll open another thread if the issue isn't the same as OP.
Ubuntu 12.04
Linux htpc 3.2.0-22-generic-pae #35-Ubuntu SMP Tue Apr 3 20:37:36 UTC 2012 i686 i686 i386 GNU/Linux
Intel® Core i3 CPU 550 @ 3.20GHz
Nvidia GT520 (295.33 drivers)
When XBMC is not running - CPU usage is less than 5%
When XBMC is open, fullscreen and idle at menu - CPU usage averages 90% for Xorg and 10% for xbmc.bin
When XBMC is open, windowed and idle at menu - CPU usage averages 65% for Xorg and 10% for xbmc.bin
When XBMC is open, fullscreen and video playing - CPU usage averages 10% for Xorg and 10% for xbmc.bin
Removing the modelines from xorg.conf fixes the high cpu in Xorg, but is not a viable solution due to EDID info not reporting properly for my plasma.
Have tried changing various settings in the Nvidia config, but none make a noticeable difference.
Have tired enabling dirty regions in advancedsettings.xml, but only a small improvement.
Changing the "Vertical blank sync" in System/Settings in XBMC to "Disabled" or "Enabled during video playback" immediately drops the high cpu in xorg. Setting it back to "Always enabled" or "Let driver choose" makes xorg cpu usage jump right back up
Any ideas on what can be done? I can post a log if needed.
(2012-04-10, 03:04)Aenima99x Wrote: [ -> ]Changing the "Vertical blank sync" in System/Settings in XBMC to "Disabled" or "Enabled during video playback" immediately drops the high cpu in xorg. Setting it back to "Always enabled" or "Let driver choose" makes xorg cpu usage jump right back up
Any reason you can't set "Vertical blank sync" to "Enabled during video playback"? If I remember correctly, XBMC doesn't use hardware acceleration to render the menus, which explains the CPU usage stats you posted.
(2012-04-10, 06:33)cowfodder Wrote: [ -> ] (2012-04-10, 03:04)Aenima99x Wrote: [ -> ]Changing the "Vertical blank sync" in System/Settings in XBMC to "Disabled" or "Enabled during video playback" immediately drops the high cpu in xorg. Setting it back to "Always enabled" or "Let driver choose" makes xorg cpu usage jump right back up
That's what I have it at right now. Just wondering why the high cpu in Xorg with it set to always enabled when that setting was always fine before Eden.
Don't use any window manager with composite extension when running XBMC. Have you tried e.g. Fluxbox? Make sure you have enabled "sync to vblank" in 3D settings of driver. On NVIdia systems you should run nvidia-settings -l in startup of window manager.
I've noticed this too, I haven't had a chance to look much at it yet but there is a significant jump in cpu use on my system.
My usage is somewhat nonstandard, which is part of the reason I've not posted until I've looked into it more.
On my Dharma virtual machine running, it idles at between 200MHz cpu usage and sits there quite happily running library updates. My recently deployed Eden virtual machine based of xbmcbuntu idles a about 2000-2300MHz cpu usage.
As I mentioned, my usage is far from standard so may or may not be relevant - but certainly it seems to be eating cpu resources where previous release didn't.
That's XBMC in main menu on a Zotac ID80. RSS feed disabled.
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1750 xbmc 20 0 548m 99m 40m S 3 2.6 0:22.14 xbmc.bin
952 root 20 0 158m 39m 18m S 0 1.0 0:04.13 Xorg
1848 xbmc 20 0 21468 1340 988 R 0 0.0 0:00.36 top
1 root 20 0 24192 2264 1324 S 0 0.1 0:01.47 init
2 root 20 0 0 0 0 S 0 0.0 0:00.00 kthreadd
With RSS feed enabled xbmc uses approx. 14%. I have algorithmdirtyregions set to 3.
That means the entire gui gets rendered because of RSS feed.
Eden - xbmcbuntu installation - idle
top - 17:04:15 up 2 days, 17:10, 1 user, load average: 1.12, 1.07, 1.06
Tasks: 140 total, 2 running, 138 sleeping, 0 stopped, 0 zombie
Cpu(s): 97.7%us, 2.3%sy, 0.0%ni, 0.0%id, 0.0%wa, 0.0%hi, 0.0%si, 0.0%st
Mem: 2056772k total, 1338668k used, 718104k free, 169836k buffers
Swap: 2095100k total, 0k used, 2095100k free, 614548k cached
12071 prae 20 0 798m 144m 23m R 95.9 7.2 2290:51 xbmc.bin
953 root 20 0 293m 51m 8580 S 3.0 2.6 94:40.41 Xorg
1288 root 20 0 87472 4140 3176 S 0.3 0.2 1:40.45 vmtoolsd
1597 prae 20 0 197m 12m 9900 S 0.3 0.6 14:31.13 metacity
1753 prae 9 -11 280m 4952 3268 S 0.3 0.2 10:49.46 pulseaudio
20895 prae 20 0 91948 1708 836 S 0.3 0.1 0:00.01 sshd
Dharma Install (whilst doing library update)
top - 17:06:35 up 1 day, 6:17, 1 user, load average: 0.18, 0.06, 0.06
Tasks: 135 total, 2 running, 133 sleeping, 0 stopped, 0 zombie
Cpu(s): 49.2%us, 8.7%sy, 0.0%ni, 39.8%id, 0.0%wa, 0.0%hi, 2.3%si, 0.0%st
Mem: 2062328k total, 868508k used, 1193820k free, 100292k buffers
Swap: 2095100k total, 0k used, 2095100k free, 492688k cached
3502 xbmc 20 0 379m 63m 19m R 57.1 3.1 0:11.25 xbmc.bin
3516 xbmc 20 0 18336 3404 2548 S 2.7 0.2 0:00.23 smbd
1632 xbmc 9 -11 149m 4316 3092 S 0.7 0.2 0:00.09 pulseaudio
1442 root 20 0 33860 3644 2932 S 0.3 0.2 0:55.75 vmtoolsd
3381 prae 20 0 9860 1540 852 S 0.3 0.1 0:00.02 sshd
1 root 20 0 3316 1832 1260 S 0.0 0.1 0:01.51 init
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
Dharma - idling
top - 17:11:46 up 1 day, 6:22, 1 user, load average: 0.06, 0.19, 0.13
Tasks: 135 total, 1 running, 134 sleeping, 0 stopped, 0 zombie
Cpu(s): 45.2%us, 8.3%sy, 0.0%ni, 43.5%id, 0.0%wa, 0.0%hi, 3.0%si, 0.0%st
Mem: 2062328k total, 880472k used, 1181856k free, 100500k buffers
Swap: 2095100k total, 0k used, 2095100k free, 495724k cached
3502 xbmc 20 0 341m 57m 19m S 51.8 2.9 3:18.33 xbmc.bin
3516 xbmc 20 0 18336 3404 2548 S 6.3 0.2 0:12.82 smbd
1442 root 20 0 33860 3644 2932 S 0.3 0.2 0:55.91 vmtoolsd
1632 xbmc 9 -11 149m 4316 3092 S 0.3 0.2 0:01.20 pulseaudio
1658 xbmc 20 0 41652 12m 10m S 0.3 0.6 2:12.01 vmtoolsd
Just spent a little time looking at this and it may not be Dharma to Eden related.
I just started up a Eden BETA2 virtual machine and it runs and idles similar to the Dharma machine. I wonder if it is something specific to the xbmcbuntu install or the eden final release that is causing it.
I'll do an update on the beta2 machine to final and see if it jumps in cpu usage.
Guys - please keep this thread on topic: if your problem does not related to high CPU usage on idle then don't post here. Start your own thread.
(2012-04-10, 20:56)graysky Wrote: [ -> ]Guys - please keep this thread on topic: if your problem does not related to high CPU usage on idle then don't post here. Start your own thread.
Everyone is talking about idle issues.....
