2012-04-10, 00:10
Hello guys,
First I would like to say thank you developers for the hard and successful work you have been doing on this amazing software, I'm using it since last year and it's my favorite in its class.
My situation is that i have some playlists with tv channels that are all rtmp streams, i have a MCE remote controller configured to change channels when you press channel up and down, so it's just like a cable tv. I have no concerns about the channels quality, they are great!
But unfortunatelly sometimes when you press up or down the xbmc hangs and it won't respond at all, even alt+f4 won't work, you need to open the task manager to close it the hard way.
The same thing happens with programs like RTMPGUi+ and SuperTV. sometimes when i go to change the stream it just hangs...
I'm using windows 7 home premium 64Bits.
I tested in more than one PC and the same situation happens on a 32bit windows 7 running EDEN.
I hope anyone has a hint or solution to this problem, so i can watch my custom cable tv
Thank you guys, sorry for my bad english.
